Old 12-02-2012, 06:29 PM
Atuckman Atuckman is offline
Default 68 nova - cowl tag
trying to help someone with this.
06D E
68-11427 WRN XXXXX
733
when i checked a couple resources, the 68 cowl tags seem to lack the first line as i described...
any help would be appreciated
Old 12-02-2012, 06:41 PM
69 Post Sedan's Avatar
Default Re: 68 nova - cowl tag
Adam, have you checked these links out?
Kurt
Nova Trim Tag Info
1968 Trim Tag
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 12-02-2012, 07:59 PM
Hello Atuckman,
in 68 the date code and interior paint codes are on the top line. They moved down on the tag in 1969.
Greg
Old 12-02-2012, 08:34 PM
Thanks guys.
The last line is 733. R-R
What is the E on the top right for?
Appreciate the help
Old 12-02-2012, 08:46 PM
motionwannabe motionwannabe is offline
733=Black Vinyl Bench (standard) RR= Matador Red
68= year 1=chev 14=chev II Nova v8 27+2dr Seadn WRN=Willow Run Mich. Plant
I couldnt find anything on the E
Old 12-02-2012, 08:53 PM
Th "E" is the interior trim code...probably stands for black trim.
The 733 is the for a standard black vinyl bench seat
R-R Red Paint top/bottom
Old 12-03-2012, 01:41 AM
If I remember correctly, the trim tag will always show 11427 v8. You need to check the VIN nbr to see if it's a v8 If it shows 11427, you're golden. 11327 6cyl 11227 4 cyl. Nothing will designate big block on either.
