Old 09-28-2012, 12:09 PM
my69rat my69rat is offline
Default 69 Nova With Dual Horns
I have a 69 Nova SS I want to put dual horns on. Does anyone have a 69 with the dual horn setup that I can see where to put the other horn. My car has the horn on the drivers side fender behind the water bottle. There has to be a spot somewhere you can put the other horn I cant find it though. You could order dual horns so there has to be a spot for them.
Thanks
Old 09-28-2012, 12:57 PM
Default Re: 69 Nova With Dual Horns
If you could have gotten two horns, it should be in the Assy Manual. I will check later, not sure I agree with you about 2 horns ?
Mike
Old 09-28-2012, 10:50 PM
Thank you Mike, the RPO code for the dual horns were U05
Old 09-28-2012, 01:40 PM
Igosplut's Avatar
Igosplut Igosplut is offline
If I'm remembering correctly they were both on the drivers fender, One mounted inside and the other outside. One bolted thru to the others bracket (same hole) which was threaded.
WOT
Old 09-29-2012, 02:08 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Igosplut</div><div class="ubbcode-body">If I'm remembering correctly they were both on the drivers fender, One mounted inside and the other outside. One bolted thru to the others bracket (same hole) which was threaded. </div></div>
Thank you, I cant put it there the water bottle for the windshield washer is in the way.
Old 09-28-2012, 01:43 PM
67 Nova Boy's Avatar
http://www.americanautowire.com/PDFL...20IN%201.0.pdf
http://www.novareference.com/manuals...iring_left.jpg
http://www.novareference.com/manuals...ring_right.jpg
Dave
67 Nova Boy
Old 09-29-2012, 02:04 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 67 Nova Boy</div><div class="ubbcode-body">http://www.americanautowire.com/PDFL...20IN%201.0.pdf
Dave
67 Nova Boy </div></div>
Thank you for the information.
Old 09-28-2012, 01:49 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
69 Rat,
The second horn was positioned just below the horn relay. I have the assembly manual page I can scan and send to you if you wish...PM me with your email address.
Martin
Old 09-29-2012, 08:10 PM
Nova Jed Nova Jed is offline
My 69 has dual horns as well. One on inside of fender, the other is on the rad support just below the voltage regulator.
Jed
Old 10-01-2012, 03:33 AM
Plowman's Avatar
Plowman Plowman is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Nova Jed</div><div class="ubbcode-body">My 69 has dual horns as well. One on inside of fender, the other is on the rad support just below the voltage regulator.
Jed </div></div>*Nova Jed is over their private topic limit. Clean out your pm's they are full, thanks *Paul* have some up dates,for you.
