New & Used 1969 Camaro (& Nova) Parts…good, bad and ugly...L-O-L.
(unless noted, all of the parts below are for 1969 Camaro & Nova) New Old Stock GM Rag Joint. Part Number 780639. $125.00 New Old Stock GM Nova Headlamp Bezel. Part Number 03949790. $169.00 Delphi Manual Steering Box (525 box, standard ratio), new in original box. $333 L88 LS6 L71 L72 ZL1 Chevrolet Corvette, Camaro, Chevelle Big Block Rocker Arm studs, 7/16. New Old Stock OEM Chevrolet. $40.00 Small Block Crankshaft Pulley. Car had power steering. Pulley is in very nice overall condition. $29 Small Block Water Pump Pulley. Very nice overall condition. $29 Alternator Pulley. Standard groove configuration. Very nice overall condition. $10 Small block (motor) frame mount brackets. Engine mount pads @ subframe. Mint OEM used. $40 Automatic Transmission Brake Pedal. GM. Mint used. Includes perfect OEM pad, bushings & cross shaft . $40 Heater Hose Clip. Clips to passenger side inner fender. GM. Mint used. $8 Vacuum Advance Tube Clip. Small block. Mint. OEM Used. Difficult to find part. Fits on passenger side of intake manifold to hold vacuum advance steel line in place. $10 Front Drum Brake Assemblies. Complete. Mint. Came off 9300 original mile car. $150 pair Front Drum Brake Hubs. Mint. Came off 9300 original mile car. $50 pair Front Park Brake Cable. Mint. Came off 9300 original mile car. $35 Rear Park Brake Cables (Nova). Mint. $50/pair Raybestos “Raymold” Bonded Brake Shoes (rear set). P/N 242RP (Camaro-Nova-Chevelle, etc.). New in box. $24.00 1967-68 Camaro; 1968 Nova Big Block Water Pump Bypass Hose. New Old Stock GM. $35.00 Small Block Heater Core. Perfect shape. Includes seal. $39 Windshield Washer Jar. Has some yellowing, but otherwise perfect. $9 Small block valve cover to air cleaner hose, pipe, grommet & clamps. Mint. $5 Side marker lens assemblies, new. Complete set of 4. No chrome trim. $25 Twist in oil filler cap. Very nice painted original. $7 Mirror base gasket (driver side) $1 Wire gutter (at firewall cowl); one hole has a tear in it. $1 Automatic transmission reverse interlock. $20 Steering rag joint. Very nice condition. $25 Fan clutch (1968 Nova & 396 Camaro). New. Reproduction $150 Stick shift pedals (pedals only; no clips or bushings). New. Reproduction. $75 Aero wiper blades. New. OEM Style Reproduction. $50 Column shift steering column, partial. Includes lower + Upper key/turn signal housing & shifter housing. Very nice condition. Upper key/turn signal housing has small flat dent. $40 Hood to cowl ledge weatherstrip. Nice shape. $5 Powerglide Transmission kickdown rod. Good shape. $5 Carburetor air cleaner wing nut. Correct original. $5 Rubber hood bumper set. Used. Decent shape. $2 Windshield wiper motor mount bushings. Good condition. $2 Front brake hoses (drum brake). Good condition. $10/pair Correct distributor clamp with correct hold down bolt. Nice shape. $49 Internal horn switches (inside steering wheel). Mint. $5 Nova Trunk Lid emblem. Mint OEM GM part. $35 Original Nova Gas Tank. **Tank is Damaged**. Has a dent on one side. Includes a mint sending unit. No cap. $69 1969 (&1968) LH Nova Tail Lamp Housing. **Housing is Damaged**. $5 1969 (&1968) RH Nova Tail Lamp Assembly. Very Nice Condition. Complete. $50 1969 (&1968) LH Nova Tail Lamp Lens Assemblies, including gasket. Very nice condition. $15 Nova Tail Lamp to Body Gaskets. OEM GM. Very Nice Condition (Pair) $5/pair Nova script front fender emblems. OEM GM. Nice shape. $20 each Shoulder harness strap. Pale green in color. $2 1969 (&1968) Nova Park lens gaskets. Nice shape. $1 Nova Front bumper bracket, passenger side inner. Fresh powder coat. Mint. $15 Nova Front bumper bracket, passenger side outer. Dented. Can be repaired. $5 Nova Hood lip molding (chrome trim for nose). Reproduction. Minor dents (can be repaired). $30 Nova Hood emblem. Reproduction. Not perfect; has minor ripples in it (driver quality). $20 __________________________________________________ ______________ E-Mail: wscraba "at" telus.net (swap the "at" for @) Thanks for the room Yenko.net! Wayne |
