Old 02-06-2012, 04:12 PM
Zach Carter Zach Carter is offline
Default 1969 Chevelle Horns and Wiring
Does anyone have any pictures of how the dual hornes are supposed to me mounted on the hood latch? I also need to see how the wiring from the horn relay to the horns is supposed to be routed. Any help is appreciated. I should have taken better pictures...
Zach Carter
1969 Biscayne L72 M22 Real
1972 Nova SS-Former Drag Car
Old 02-07-2012, 01:51 AM
Don_Lightfoot's Avatar
Default Re: 1969 Chevelle Horns and Wiring
Here's a couple of images Zach. Hopefully they will help.
Specialized Chevrolet Decals
Old 02-14-2012, 12:26 AM
Don`t forget the horn wire clip(s).... not pictured in Don`s photo.
Old 02-14-2012, 01:30 AM
Thanks for the picture. It did help. I'm also trying to see how the harness comes off the horn relay and routes to the horns.
Zach Carter
Old 02-14-2012, 02:02 AM
Zach,
Simply run wire through the hole (with the factory grommet) attach to harness... run the wires up under the header panel, use the clips (shown in picture)
Shows complete illustration in assembly manual.
