Old 01-06-2012, 11:16 PM
61cad 61cad is offline
Default International Dragmaster?????
I have a set (4) of 15"x6" International Dragmasters with caps for Chevy Bolt pattern............... What are they worth?
Old 01-06-2012, 11:37 PM
Jim Ferron Jim Ferron is offline
Default Re: International Dragmaster?????
I have a set too. Paid $200 for em, then had to restore them...
www.68hurstolds.com 'Russ Dunmire Hurst Olds'
www.classicperformance.com 'Cars'
Old 01-07-2012, 04:49 AM
Jim:
Who restored your wheels and how much did it cost you?
Old 01-07-2012, 06:15 PM
I did it myself...Fine sand blasted the spokes and polished the rim myself.
I actually use the rear axle on the car as my lathe...jack it up ..bolt the wheel on [no tire] make sure everything is safe...jack stands, blocked front wheels, Tailpipe vented out the door.. Then I use sandpaper first , then a die grinder with a buffing wheel on and different compounds.One set I actually finished with 180 grit sand paper to give it a machined look.
I personally can't get aluminum to polish up like 'chrome' I can get it pretty good but the pros do better.I don't know what I'm doing wrong but...
I've done two sets of Hurst wheels, just the spokes...one set I did myself with a die grinder. Probably 4-5 hours a wheel...second set I set out to magmasters...way nicer job. Here are before/after on the Dragmasters...I don't have the correct international center caps..I have Americans and ET ovals...Someday I'll find the right ones...I think I saw 'em someplace...
Old 01-09-2012, 10:10 PM
ORIGLS6 ORIGLS6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jim Ferron</div><div class="ubbcode-body">I did it myself...Fine sand blasted the spokes and polished the rim myself.
I actually use the rear axle on the car as my lathe...jack it up ..bolt the wheel on [no tire] make sure everything is safe...jack stands, blocked front wheels, Tailpipe vented out the door.. Then I use sandpaper first , then a die grinder with a buffing wheel on and different compounds.One set I actually finished with 180 grit sand paper to give it a machined look.</div></div>
[img]<<GRAEMLIN_URL>>/worship.gif[/img] [img]<<GRAEMLIN_URL>>/worship.gif[/img] [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 01-08-2012, 11:20 PM
YENKO DEUCE REGISTRY's Avatar
Wow!
Marlin
Old 01-10-2012, 06:48 AM
Tommy Tommy is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">Wow! </div></div>
My thoughts exactly !!
Tommy [img]<<GRAEMLIN_URL>>/[/img]
Old 01-10-2012, 03:24 PM
day2killa day2killa is offline
those came out really nice
