Old 11-15-2011, 01:37 AM
Default JukeBox Remote WallBoxes
Officially known as "Wall-ettes".
These were made in 1966,as companions to the 1965 AMI Rowe Diplomat Jukebox,that would hang on the wall of the Diner at each table.
The Jukebox itself is for sale in this same section w/pics.
Each has multiple lights,that glow inside when hooked up to a power supply.The rotary circle on the top center is how you select your song.
The first 4 pics are one box..the second 4 are the other.
Both are very nice and clean.One is cleaner then the other,and has it's key.Both measure 16" across X 7" deep X 12" high.
$100 for EACH one and can be shipped,but the weigh about 50lbs. each so that could be costly.
I can deliever these to MCACN this week if desired.
Rick REDL78@ATT.net
Old 11-15-2011, 05:07 AM
Plowman's Avatar
Plowman Plowman is offline
Default Re: JukeBox Remote WallBoxes
The Jukebox for sale,I can't see pictures,needs a stepper in it. I found it.
Old 11-15-2011, 05:32 PM
Yes,the steppers are not included here,but can be found if you want it to interact with the JukeBox.
This is for the wall boxes only.They look good hanging on a garage or basement wall.
You can be a lower volt transformer at RadioShack that steps down the voltage,and allows you to make the bulbs illuminate inside this.
I fixed the pics,so you should be able to see them now.
Old 11-16-2011, 03:27 AM
Need to make room here,so I'll lower the price to $75 each.
Old 11-18-2011, 02:14 AM
Both sold
