Old 08-28-2011, 05:26 AM
Default slow heating
OK, Maybe someone has an idea,
Im pretty sure this is the factory set up. radiator recored, water pump ok, thermostat replaced, stock timing setting, clean coolant.
Problem: Sitting at idle the car will slowly heat, and continue to heat up very slowly, if I drive it will cool back down,
The assembly manual shows the setup as you see, assuming it is stock, any ideas?? It is now running a 180 standard themostat, oem appears to be 195. Assuming factory stock the system even though build without a shroud should run at the thermostate temp?? shouldn't it
Carl
Old 08-28-2011, 07:37 AM
Default Re: slow heating
No fan shroud ?
Old 08-28-2011, 07:49 AM
Plowman's Avatar
Plowman Plowman is offline
You could try drilling a 1/8" hole in the thermostate. This will let the air out of the cooling system that gets traped. Paul
Old 08-28-2011, 08:04 AM
Try a 160 stat in it. I never run anything over a 160 in these cars.
Old 08-28-2011, 02:57 PM
VintageMusclecar's Avatar
Operating temps of 195° and above were fine back in the day when we had decent gasoline, but these older carbureted cars simply do not seem to like to run right at those temps with today's gasoline. I can't begin to count how many complaints I've heard about running hot and constant heat soak/vapor lock problems on these older cars.
Also consider that the gas today is formulated for EFI (--there hasn't been a domestic carbureted vehicle available since ~1985). The ~10% ethanol in today's gas typically causes older carbureted cars to run a little lean, esp. at idle/low speeds, which can cause engine temps to rise.
I would first try adding a better fan and installing a shroud as suggested above. This alone may resolve the issue, but if not, you could try richening up the idle on the carb just a bit and perhaps try bumping the timing a little as well, that may help alleviate the creeping temps.
I'm also a big advocate of 160°-180° `stats in these older cars as well.
Old 08-28-2011, 03:21 PM
MosportGreen66's Avatar
160 deg Milodon Thermostat! Best out there...
How old is that radiator core? Looks like it has miles on it.
Old 08-28-2011, 04:58 PM
scuncio's Avatar
scuncio scuncio is offline
The 160 degree stat is a good idea but I bet the lack of shroud is 'the' problem. What shroud design were BB Novas supposed to come with?
Old 08-28-2011, 06:06 PM
Shroud is a definite. Try a 1 inch bigger crank pulley, or a 1 inch smaller water pump pulley. On my 68 Impala I have put on a electric fan on the front(pusher) for if I'm in parades.
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 08-28-2011, 06:15 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Also you can try "Water Wetter" that stuffs really helps.
http://www.summitracing.com/parts/RED-80204/
Old 08-30-2011, 03:28 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69SSZL1</div><div class="ubbcode-body">Also you can try &quot;Water Wetter&quot; that stuffs really helps.
</div></div>
That water wetter is interesting I read the tech info on it, I never realized that glycol coolant / antifreeze actually was less conductive than regular water.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">removal of heat from an aluminum bar at 304°F by
quenching the bar in different coolants at 214°F under
15 psi pressure. Compare the time required to reduce
the temperature of the aluminum to 250°F, or the boiling
point of water at 15 psi. Red Line with
WaterWetter® required 3.2 seconds, water alone 3.7
sec, 50/50 glycol in water required 10.2 sec, and
100% glycol required 21 sec. Water alone required
15% longer, 50/50 glycol 220% longer, and 100% glycol
required 550% longer.</div></div>
Cool Stuff! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Carl
