Old 08-19-2011, 05:00 PM
chevman71 chevman71 is offline
Default ALUMINUM CASE T-10 CHECKING WHAT VEHICLE
Seeing if I could get some help identifing a T-10 aluminum case. Case is stamped WL2922(which is 4-speed, Dec 29th 1962, second shift) but has a partial vin of 149099. Check to see if anyone knows what kind of a car this is from and if it is worth rebuilding. Thanks for any help, Randy
Old 08-19-2011, 06:04 PM
Fast67VelleN2O's Avatar
Default Re: ALUMINUM CASE T-10 CHECKING WHAT VEHICLE
What is the tail shaft casting number and is there a letter before the partial vin?
-Matt
Day 2 is Life.
Old 08-20-2011, 03:54 PM
Casting # for tail shaft is T10-7D 3813490 DATED 11 2 62. There wasn't a letter before the partial vin. Thanks, Randy
Old 08-20-2011, 03:11 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chevman71</div><div class="ubbcode-body">Seeing if I could get some help identifing a T-10 aluminum case. Case is stamped WL2922(which is 4-speed, Dec 29th 1962, second shift) but has a partial vin of 149099. Check to see if anyone knows what kind of a car this is from and if it is worth rebuilding. Thanks for any help, Randy </div></div>
Actually &quot;L&quot; is November. Looks to be from an early '63 passenger car. A few plants neglected to stamp the plant letter in front of the sequence number. Does it have a front bearing retainer for a small hole bell or a large hole. Easy way to tell is if the retainer extends past the bolt heads.
Verne [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Old 08-20-2011, 03:59 PM
Thanks for the info, looks like small hole bellhousing(retainer doesn't expand past bolts) Does that put in the Impala, caprice style cars? tailshaft has bowtie on it.
Old 08-20-2011, 04:06 PM
That would make it for a Biscayne, Belair, Impala (1963) with a 327/300hp. I might be able to narrow down the plant if you post a photo of the partial VIN since different fonts and styles were used at various plants.
Verne
Old 08-20-2011, 11:32 PM
RNDSTARSTORM@AOL.COM
If you could email me I could send a pic, not sure how to load pics on this site.
Thanks for your time, Randy
Old 08-21-2011, 04:55 AM
Randy, Sometimes data falls into place very well to answer questions. I received the photos you sent and I can tell you that the front bearing retainer is the large diameter, meaning that the trans was from a 409 car using the 553 bellhousing. The VIN font is definitely from a Tarrytown built car. Tarrytown was one of the plants that tended to forget the letter code before the sequence number and also, they had a problem with the digit &quot;1&quot; during the '62 model year and replaced them with a &quot;1&quot; that was a little taller than the rest of the numerals (as yours is). Also, figuring the final production date of your car at the Tarrytown plant, it was assembled 1-2 days before the end of November, which matches the trans assembly date.
I don't know if any of this really helps you in any way, but the research is always interesting for me.
