Old 08-09-2011, 06:27 PM
whitetop whitetop is offline
Default Best protective wax or coating for cadmium plated
What are you all using to keep you cad parts looking like new?
Need something that hay and shaft won't stick to...don't ask.
Thanks
Old 08-09-2011, 06:35 PM
Guest
Posts: n/a
Default Re: Best protective wax or coating for cadmium plated
I use a spray on protective coating called Fluid Film. Spray and wipe off excess. Don"t think hay will stick to it, not sure about the schaft.
Old 08-09-2011, 09:32 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: frankk</div><div class="ubbcode-body">I use a spray on protective coating called Fluid Film. Spray and wipe off excess. Don&quot;t think hay will stick to it, not sure about the schaft. </div></div>
Thanks
I was on a tractor site and this is what they recommended.
Old 08-10-2011, 05:01 AM
camaromb camaromb is offline
Krown makes a great protective coating also. Its sold in Canada and is used on farm equipment and vehicle undercarriages. I also used it to soften the rattle can undercoat on a '70 Trans am, it worked great.
Mark
Old 08-10-2011, 04:11 PM
How about Boeshield T-9?
Old 08-10-2011, 07:25 PM
ORIGLS6 ORIGLS6 is offline
My limited experience with Boeshield; it remains slightly tacky. Might attract/hold the chaff.
Not complaining, mind you. I love the stuff, but it might not be the answer for this application.
Old 08-09-2011, 07:21 PM
njsteve's Avatar
njsteve njsteve is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitetop</div><div class="ubbcode-body">Need something that hay and shaft won't stick to...don't ask.
Thanks </div></div>
You mean hay and chaff? [img]<<GRAEMLIN_URL>>/smile.gif[/img]
OK farm boys, start chiming here.
Old 08-09-2011, 09:27 PM
Check with Schonye...he's from farm country!
Old 08-09-2011, 09:31 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitetop</div><div class="ubbcode-body">Need something that hay and shaft won't stick to...don't ask.
Thanks </div></div>
OK farm boys, start chiming here. </div></div>
Yes, chaff.
Old 08-10-2011, 08:24 PM
Best way to spray Boeshield is to spray it on and let the solvents evaporate (1/2 to 1 hour depending on temperature and humidity) and then take a clean cloth and gently wipe the excess wax off. I have done this for years and it does not leave a film this way and wont attract dirt/dust.
