Old 06-28-2011, 12:58 PM
jasonL78 jasonL78 is offline
Default 68 Nova/Camaro power brake/ clutch pedal assembly
Looking for someone to verify on a 68 nova/camaro a return spring was used for the brake/clutch pedal assembly on power brake cars?? I was restoring my brake clutch pedal assembly from the 68 L79 and noticed from Gregs Nova research page that it was missing the brake pedal return spring. So I went and checked my 68 L78 Nova that also is an original power disk brake car and it also didn't have a return spring? From what I can see on the L78 the diaphram holds pressure against the pedal so no spring would be needed. Can I assume this is correct?
Picture #8 is what caught my eye maybe Greg can explain.
http://www.chevynova.org/1968ClutchPedals.html
Old 06-28-2011, 02:16 PM
Default Re: 68 Nova/Camaro power brake/ clutch pedal assembly
4:58 AM [img]<<GRAEMLIN_URL>>/shocked.gif[/img]
I don't get up that early to go deer hunting [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Jason...I will check the yellow car and see if the spring is there...we can also check the parts for the other 68 and see if it has the spring...tom
Old 06-28-2011, 03:10 PM
You should try it and your luck might change this hunting season. [img]<<GRAEMLIN_URL>>/laugh.gif[/img] [img]<<GRAEMLIN_URL>>/laugh.gif[/img]
Thanks for looking I will call you later.
jason
Old 06-30-2011, 04:09 PM
I guess I will have to try the nova site for this information. [img]<<GRAEMLIN_URL>>/frown.gif[/img]
