I got my car out on Friday for the first time this year and it fired right up and idles perfectly but after warm up I went to cruise around the neighborhood and I could not get out of first gear, as soon as you give it throttle, it pops and runs eratic. I did not have time to check it out, any suggestions on where to start looking for the problem.
Thanks in advance for your input. |
After I checked my firing order, pulled the dist cap, check the condenser, checked the timing with a light, and assuming there are no radical changes/jumps /erratic readings when running it up in garage. NEXT
I would pull the valve covers and see if I had any loose rocker arms.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
You can try this with #5 and #7 cylinders spark plug wires have to be crossed going to the plugs or induction will happen and cause misfiring. Paul
Maybe the points are corroded or there is moisure in the distributor.
Jason |
Put some fresh gas in it....
![]() The Best things in life......Aren't Things |
Thanks guys for all your input, I will check it out next week. The gas in the car is Cam 2 from last year, hopefully it is still good at $8 per gal.
This years $12.00 per gal MUST be better.... [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Check your spark plugs also.. They do weird things.... Start with the easy/basics.... That Cam 2 won't go bad...
Rich
"This is Sheriff Buford T. Justice, I'm in pursuit of a black Trans Am, he is all mine so stay out of the way" |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr. Chevy</div><div class="ubbcode-body">Check your spark plugs also.. They do weird things.... Start with the easy/basics.... That Cam 2 won't go bad...
Rich </div></div> X2
1969 9566AA COPO Chevelle M-22 1969 Malibu 489 ZL-1 T-56/4.56 1969 Beaumont 540 th400 3.70 1969 Chevelle 300 Deluxe 427 ZL-1 M 22W 1970 Olds 442 W 30 2 door post 1969 Ply. GTX 426 hemi auto. Blue. 1940 Dodge pick up Durango 4X4 1968 Camaro ragtop LSA ZL1 |
If you put it away last year and it was running good I would first go with a new set of plugs like Rich suggests. Could be carb issues. maybe the Cam 2 ate the accelerator pump up. Check your dwell and make sure the mice did not chew on your plug wires. If it is a BB I bet plugs and maybe some gum from the gas. Suppose to run these cars in the winter you know Jeff. NO lawn ornaments.
