Old 03-30-2011, 06:42 PM
69 Post Sedan's Avatar
Default 1970 CE Stamp
I picked up a 4 bolt main 3969854 block cast H.30.9 and wanted some opinions on the stamp.
It appears it started out as a T0916KE then it was ground down at Tonowanda then it bacame a CE070400. On the bottom of the block where the starter bolt on is stamped T099. Broach marks are very clear everywhere on the block but under the stamps.
My theory is it was stamped to go on a car but then it turned into a CE block before it went out the door????
Thanks, Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-03-2011, 06:35 PM
Kristoffer Kristoffer is offline
Default Re: 1970 CE Stamp
What does the T099 means?
L88 Camaro
Old 04-03-2011, 08:02 PM
That is the build date of the motor. 9th mo 9th day. Same format that would be on the top pad for a production engine.
Typically CE blocks were stamped on this machined pad near the starter.
Looks like they could not figure out what to do with this block... [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 04-03-2011, 09:27 PM
Is it only on CE blocks this date is stamped by the starter?
I have a engine block with T089, but the castingdate is H 23 9, could T089 be 8th day in 9th month?
L88 Camaro
Old 04-04-2011, 01:59 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kristoffer</div><div class="ubbcode-body">I have a engine block with T089, but the castingdate is H 23 9, could T089 be 8th day in 9th month? </div></div>
T089 is the 8th month of 1969 or August of 1969....no specific day.
Kurt
Old 04-04-2011, 04:07 AM
I stand corrected, thanks. If it were a specific day like up top it would be T0909
Old 04-04-2011, 01:56 AM
From what I have seen....yes, only the CE blocks are stamped down by the starter. Also, the T099 stands for the 9th month of 1969.
This is what Kurt Sonen over on Team Camaro said about the block.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">KE is for the MA6 dual clutch. Production total of zero. They made up this engine but it was never installed since the RPO was never orderable. Tonawanda then converted it to a CE block and sent it out the door.
Interesting they got this far towards actually building MA6 cars....</div></div>
Kurt
Old 04-04-2011, 07:05 AM
Thank you guys. I dont want to hijack the tropic, but I have one more question.
Could you buy a L88 shortblock over the counter in 1969? Or was it only complete engines?
L88 Camaro
