Old 02-22-2011, 10:07 PM
Fast67VelleN2O's Avatar
Default BE 12 bolt questions
Is there a different part number (from a stock 4.10 gearset) stamped into the ring and pinion on a BE COPO 12 bolt gear set? If so, what is it?
-Matt
Day 2 is Life.
Old 02-23-2011, 12:00 AM
Default Re: BE 12 bolt questions
The 4:10 ring & pinion gear part #3917971 is what Chevrolet used on the BE COPO.
Old 02-23-2011, 12:33 AM
427king 427king is offline
Yenko Paid Member
"Is there a different part number (from a stock 4.10 gearset) stamped into the ring and pinion on a BE COPO 12 bolt gear set? If so, what is it?".....................the standard ring and pinion in a 410 axle is #526 and #528, while the copo 410 gears are #226 and #228..
Old 02-23-2011, 03:35 PM
ANDY M's Avatar
ANDY M ANDY M is offline
It should look like this:
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 02-23-2011, 03:55 PM
69 Post Sedan's Avatar
https://www.yenko.net/ubbthreads/ubbt...p;Number=20330
Per Ed Cunneen:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">The part number for the 4.10 set was 3917971.
The ring and pinion part numbers are as follows:
3916226 Ring Gear 3916228 Pinion Gear
Case part number was 3916234 </div></div>
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 02-23-2011, 05:10 PM
Ok.... so it looks like I have a set of these gears that came with a 174 posi unit I bought back in October. They have been sitting on the shelf ever since. How do I tell if the posi unit is a COPO unit without taking it apart?
Day 2 is Life.
Old 02-23-2011, 05:36 PM
Here are some photos of what I picked up.
Day 2 is Life.
Old 02-23-2011, 06:01 PM
scuncio's Avatar
scuncio scuncio is offline
I think the correct side gears have no 'flange' on the sides facing the clutch plates. Hard to tell from your picture.
Old 02-23-2011, 06:16 PM
Alss's Avatar
Alss Alss is offline
How about the difference in the dates..5-69 and 1-70?..did the factory gears come in sets??..I have a standard 4 10 gear set in my COPO and both gears have the sama date..just curious and do not want to diminish the value of these gears..oh and by the way [img]<<GRAEMLIN_URL>>/Can-I-Have-It.gif[/img] [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Albert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-23-2011, 06:12 PM
69L72RS 69L72RS is offline
Matt,
That is a standard duty 4-series unit, based on the posted pictures.
Here is a #234 unit to compare.
