Old 02-13-2011, 08:54 AM
dakotakid dakotakid is offline
Default Paint on fender wells and firewall
I have a '69 Berger Camaro with a fairly decent restoration. One problem though...when the restoration was done, the fender wells and firewall were painted gloss black. Rather than take everything apart and redo it all, is there a way with some type of compound or mild chemical to "flatten" the paint somewhat (without removing it), so that it has a semi-gloss satin appearance? Thanks.
Old 02-13-2011, 01:11 PM
Default Re: Paint on fender wells and firewall
shouldn't the fenderwells be undercoated?
Old 02-13-2011, 02:53 PM
I think he's referring to the fenderwell that is seen when you open the hood; or maybe they're called the inner fenderwell?
Old 02-13-2011, 05:16 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dakotakid</div><div class="ubbcode-body">I have a '69 Berger Camaro with a fairly decent restoration. One problem though...when the restoration was done, the fender wells and firewall were painted gloss black. Rather than take everything apart and redo it all, is there a way with some type of compound or mild chemical to &quot;flatten&quot; the paint somewhat (without removing it), so that it has a semi-gloss satin appearance? Thanks. </div></div>
On an inconspicuous place, try scrubbing it with Comet abrasive cleaner using a sponge. Seems like I did this about 30 years ago on a part that was too glossy. I believe a very fine brass wool dipped in water might accomplish the same effect. Don't use steel wool, as the fince particles left behind will rust residue.
Old 02-13-2011, 06:05 PM
I was going to even suggest trying some very course rubbing compound. Anything with course abrassive is going to give it a hazy apperance, may look funky when the sun hits it ?
Mike
Old 02-14-2011, 01:03 AM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">I was going to even suggest trying some very course rubbing compound. Anything with course abrassive is going to give it a hazy apperance, may look funky when the sun hits it ?
Mike </div></div>
That's correct Mike, any abrasive will show scratch(swirl) marks on a former gloss finish when the sun hits it. Maybe a product like Prepsol or another cleaning solvent with isopropoyl alcohol. Like above, test a small area.
Old 02-14-2011, 04:58 PM
Alss's Avatar
Alss Alss is offline
I dont think anything will work..you can never replace a sprayed finish with any kind of rubbing..its impossible to make all the tight areas uniform..bite the bullet and do it the right way..the car deserves it!
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-14-2011, 07:39 PM
I agree with Albert.
Old 02-14-2011, 11:17 PM
Best thing to do is to dis-assemble the front end and take the parts out and have them done right, you won't regret the decision to do it correctly and I know I would kick myself for not doing it right to begin with.
Old 02-15-2011, 02:47 PM
I had a similar situation on a car a couple of years ago...the underhood pieces had a little too much gloss (inner fenders, rad. support, brackets, etc.) good thing is they weren't installed yet. So we mixed some clear that had a soft dull finish...resprayed all the parts and it came out perfect. It covered the sheen and gave it an original look and added a layer of protection. Take it apart and do it right...it is really the only way.
wilma
