Old 05-16-2010, 09:35 PM
72-SS-L48 72-SS-L48 is offline
Default Champion Spark Plugs on a L-79 Corvette?
Hi Guys,
Can someone tell me... Will Champion RJ - 1848 Resistor spark plugs work on a 67 L79 Corvette? If so what should I gap them to?
Dave
Old 05-17-2010, 12:53 AM
markjohnson's Avatar
Default Re: Champion Spark Plugs on a L-79 Corvette?
I would think a standard .035 gap and you will be fine. Large plug gaps are hard on plug wires. My father used to maintain a friend's '66 L-79 Corvette and once put Champion plugs in it and it ran terrible. Now this was probably over 20 years ago so details are forgotten. I think you oughta stick with AC's probably or even NGK's that have become very popular with members here.
Old 05-17-2010, 04:37 AM
PxTx's Avatar
PxTx PxTx is offline
I had a similar experience with some Champion plugs not running well on a 'Vette. This was a 197X disco-machine so not the same as the ignition parts in the 67.
Mark, not to nit-pic but what are your thoughts on the larger gap being hard on wires? I realize more voltage is used to jump the gap vs being there to add to the start of combustion. Are you saying the increase in gap = increase in resistance and the wires will break down sooner?
Paul III
Old 05-17-2010, 05:36 AM
SSRSBOB SSRSBOB is offline
J12YC is the perfect plug for that car.
My buddy runs them in his L79. Perfect heat range for today's gas. Also work in the Z28 too. 11 to one comp.
Bob
Old 05-18-2010, 01:38 AM
Yes Paul, you pretty much figured it out with the increased resistance making the wires break down sooner. I also wanna say that if the gap is too large with poor quality, stock type skinny plug wires that a spark can be induced from one cylinder wire to another OR just ground out to a valve cover or something, especially the consecutive-firing cylinders of #5 and #7. A friend had this problem with large plug gaps and poor plug wires on a 440-6 Pack Charger. It looked like a Fourth of July Fireworks display when the hood was open at night!
Old 05-18-2010, 05:56 AM
Belair62 Belair62 is offline
I only use Champions in my lawnmower.It's a Toro.I never had much luck with them in any of my cars..
