Old 04-18-2010, 08:32 PM
Default BE carrier numbers
Casting number for the carrier in a BE rear axle?
Heat treated ring gear is stamped with 3917971, correct?
Old 04-18-2010, 08:50 PM
Default Re: BE carrier numbers
Yes on that ring gear for a COPO 4:10 Camaro-Nova-Chevelle.
Old 04-18-2010, 08:57 PM
Anyone know the carrier casting number? Is it the same as a regular 4 series posi unit? I am not where I can look it up right now.
Old 04-18-2010, 09:51 PM
Fast67VelleN2O's Avatar
https://www.yenko.net/ubbthreads/showflat...e=1&fpart=1
Day 2 is Life.
Old 04-19-2010, 04:56 PM
69L72RS 69L72RS is offline
3917971 is the part number for the r&p set.
The numbers that are stamped into the actual gears are 3916226 and 3916228.
The 4.56 set is stamped 3916230 and 3916231.
The 4.88 set is stamped 3916232 and 3916233.
The assembled COPO carrier part nuber is 3916234.
The COPO carrier casting is 30174, just like the standard 4-series unit.
Hope this helps.
