Old 04-08-2010, 02:01 AM
4onthefloor 4onthefloor is offline
Default What kind of HorsePower ?
I have a Fresh Built BBC-454 & Would Like to Some Input As to How much Horsepower it "SHOULD" make?It's in my 1979 Trans AM- Here is my combo
Early 2 Bolt Block-040 Zero decked
Early Cast Crank-010-polished& set up for RPM's
Con Rod's-Bowtie Dimple Rods with Big Bolts
Cylinder Heads- "290" Large Oval Ports Shaved-bowl Blended-Pocket ported with Big Valves(All Ferrera Parts)
Camshaft- Crane POWERMAX-Solid Roller(Nitrous Oxide Grind)-246/254-114-615/636
Full Roller Motor-Roller Lifter's-Comp Cams-7/16 Magnums Roller Rocker's-Roller Chain-
Pushrods-TFS 9.25+.375-Full MSD ignition with HEI no vacuum
Intake Manifold-Edelbrock Performer 2-0 Permastar Finish
Carb-Im running a Holley 750 V.S--But I Have a Holley 800 DP-thats ready to be jetted to this combo..
Fuel pump-Holley Race pump with Regulator(All Electric) with BIG Gas Line-(No NOS YET)
This is connected to a H.D Manual 4 speed-with a Street/Strip Clutch & A ScatterShield-& i have a Prepped Rear end with New Internals & 3.73 gears
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers
Keystone Klassic's with Big&Little's,High Jacker Air shocks.
Old 04-08-2010, 02:32 AM
Default Re: What kind of HorsePower ?
Piston squeeze?
Jake is my grandson!!
Old 04-08-2010, 02:36 AM
sYc sYc is offline
Piston squeeze?
No thanks...
Tom Clary
Old 04-08-2010, 02:37 AM
mockingbird812's Avatar
He didn't mean squeezed by Howie!!!
Sam...
Old 04-08-2010, 03:47 AM
SpeedPro Power Forged Pistons# L2377F
Old 04-08-2010, 04:17 AM
PxTx's Avatar
PxTx PxTx is offline
I think they are asking if you know your compression ratio. If you or you engine guy cc'd the heads and you know what head gasket you are using, we can get close.
Paul III
Old 04-08-2010, 04:18 AM
-----Hard to determine without the compression ratio as every point is a bunch-o-ponies. ......Bill S
