Old 03-20-2010, 03:07 AM
sg1747 sg1747 is offline
Default dipstick
did the correct dipstick for a 1969 z 28 have a part # on it.
thanks
Old 03-20-2010, 05:08 AM
Default Re: dipstick
Originally,all 69-75 small blocks used the jade tipped dipstick w/USE SE ENGINE OIL 3951576 M stamped into it.
Old 03-20-2010, 08:29 PM
any one know what this part # is 3981019
Old 03-20-2010, 09:04 PM
USER-3965175 USER-3965175 is offline
3981019 is a service replacement part number for a dip stick use on a 1970 454 Chevelle (exc. Monte Carlo)
USER3965175
Old 03-20-2010, 10:14 PM
John Brown's Avatar
This is why I pay for the stars under my name. The information is great.
John Brown
Old 03-20-2010, 10:19 PM
Hey User man, you got that down Pat. Very good explanation. My early 1969 nova and Z/28 have the flat type tip.
Old 03-21-2010, 04:40 AM
x  Baldwin  Motion's Avatar
That's thinking with your dipstick, Jimmy !!
Old 03-20-2010, 08:49 PM
1969 thru 1971 Z28 dip stick
GM used two different style dip sticks during assembly line production, but only one is listed in the 69 70 71 Camaro Assembly Manuals
The standard production dip stick is the most popular one with the green tip handle, however GM used an optional flat tip handle which is
not listed in the assembly manuals and was never offered as a service replacement assembly like the green tip handle was
1969-71 Production dip sticks were not stamped with GM part number and did not use "SE ENGINE OIL" markings
As with many GM parts there were physical changes thru production and in service replacement dip sticks as follows:
1) 1969-1971 green tip handles were stamped with……. “ADD 8 8 FULL USE GM 6041-M QUALITY MS OIL M”
2) 1969-1971 flat tip handles were stamped with.……… “ADD | | FULL USE GM 6041-M QUALITY MS OIL E”
1969-71 handles do not have the dimple stamped in the handle
3) 1972-up green tip handles were stamped with……….. “ADD 1 QT 8 8 FULL USE SE ENGINE OIL M”
4) 1989-current green tip handles were stamped with……“ADD 1 QT 8 8 FULL USE SE ENGINE OIL 3951576 M
1972 and later handles have the dimple stamped in the handle
USER3965175
