Old 03-15-2010, 02:49 AM
69 Post Sedan's Avatar
Default 396 Build Up
This might sound like a dumb question but can a 396 2-bolt main running on pump gas with a solid roller cam get into the 11's without any power adders?
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-15-2010, 03:00 AM
VintageMusclecar's Avatar
Default Re: 396 Build Up
Easily.
Old 03-15-2010, 03:24 AM
What I am contemplating on building is a 1971 854 CE block with the pistons that were in my motor then using 077 aluminum heads with a solid roller.
Here are a couple of pictures of the pistons.
Old 03-15-2010, 03:35 AM
What car is the fire breather going in..??
sounds cool..
Old 03-15-2010, 03:39 AM
Have you c.c'ed the chambers on your 077's?
Do you already have a cam picked out?
Open chamber heads on those pistons are going to throw 1 full point plus of compression out the window, which isn't necessarily a bad thing since you're wanting to run pump gas, but you'll have to be very careful with the cam specs to keep cylinder pressure in line.
Old 03-15-2010, 03:42 AM
I was on Team Chevelle and one of the guys there had it figured out that if I run these exact pistons with 077 (118cc) I would be at about 10.37 compression.
http://good-times.webshots.com/photo...44112208IFvWcX
Old 03-15-2010, 04:59 AM
I totally missed the part # on the pistons...was thinking of the factory 11-1 pistons.
Those should work OK, just check to make sure there's no dome-to-chamber interference issues.
What about the rest of the combination?
