Old 03-01-2010, 08:50 PM
firez firez is offline
Default 68 Z28 alternator
I was a little to strong and stripped the threads out on my 68 Z alt.adjusting tang. Whats the best way to fix this so I can retain my original alternator. Thanks
1968 LOS Rallye Green Z28
Old 03-01-2010, 09:29 PM
Default Re: 68 Z28 alternator
You have 2 options. 1st and easiest way is to insert a Heli-Coil thread repair. Very strong and if done properly, hard to detect.
2nd option is to tig weld up the hole and retap. This is a lot tougher as these alternator cases are very porous castings. Again if done properly undetectable.
Hope this helps, Chris
Old 03-01-2010, 10:19 PM
Thanks Chris I will try heli-coil. I am just wanting to be able to keep the original alt. with the car as it is original. Thanks
