Old 02-13-2010, 02:04 AM
69RSZ 69RSZ is offline
Default 15X7 tourqe thrusts
would 15X7 TQs work on my 67Z? Or should I go with 15X6 TQs?The standard rim size for the 67Z is 15X6 rallys.Any opinions? I am worried about fender clearance in the front when turning.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 02-13-2010, 04:26 AM
camarojoe's Avatar
Default Re: 15X7 tourqe thrusts
It'll depend on the offset as far as clearance goes, but as far as appearance goes, 15x6's looks a ton better than 15x7s on a 1st gen camaro in my opinion.
Joe Barr
Old 02-13-2010, 08:44 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
I have run both sizes at different times. I did not have a rubbing problem when I used the 15x6s but did with the 15x7s. I was running a P215/60R15 tire and stock height suspension.
-Jon
Old 02-13-2010, 03:40 PM
Thanks,Jon I want to put them on the white Z,and use the rallys off of the white Z for the red Z untill I find a set of rallys for the red car.I was thinking of useing 15X7s so i can use em on the 69Z also.Thanks for your opinions.
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
Old 02-13-2010, 08:52 PM
tom406 tom406 is offline
Here's a couple of options to get you cast 15x7's with a bit more backspacing:
Halibrand can machine these to 4.25" BS, 1/2" more than TT D's
http://cgi.ebay.com/ebaymotors/15x7-Hali...s#ht_1165wt_912
Vintage Wheel Works V45s have 3-7/8"BS, so another 1/8". Maybe not enough.
http://www.vintagewheelworks.com/pro...heels/v45/15x7
Team # has their 5 window 15x7 available with 4.75"BS, which would essentially put the entire extra inch inboard compared to a Torq Thrust D 15x6 (w/its 3.625"BS), but not sure if there will be clearance problems with tie rod ends, sway bar, etc.
http://www.team3wheels.com/et/classic5.html#
Finally, American's new versions of the T70R Torq Thrust have 1/4" more (4") backspacing in the 15x7 version compared to the Torq Thrust D or TTO
http://www.newstalgiawheel.com/wheel...ubcat3=1011128
'69s need all the extra backspacing they can get, too, even with their bigger wheelwells.
Good luck!
Old 02-21-2010, 07:44 PM
Jon,will the 3 3/4 backspaceing work? I was told that the american raceing Ds are only available with 3 3/4 backspaceing not 3 1/2. anyone know if 3 3/4 will work on a 67 camaro?
Ron C.
67 RSZ/28
67 Z/28
71 SS LS5 chevelle
