Old 01-13-2010, 03:58 AM
lwkitt427 lwkitt427 is offline
Default TANK STICKER CORVETTE
ANY ONE KNOW THE BEST WAY TO REMOVE A TANK STICKER FROM THE GAS TANK ?
THANKS
LES
Old 01-13-2010, 04:02 AM
Default Re: TANK STICKER CORVETTE
The best way is to leave it on the tank and install another tank. Just a opinion....
Old 01-13-2010, 04:14 AM
markjohnson's Avatar
Agree with Charlie 100% on this one. Most everyone regrets removing it after they do the deed and usually end up messing it up at least a little. A 45 year old car can probably use a new gas tank anyway.
Old 01-13-2010, 05:14 AM
ssl78 ssl78 is offline
My was coming apart so I just clear taped it to the tank after I took pictures of it and put it back up.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-13-2010, 05:45 AM
THANKS GUYS. ANY MORE TIPS I AM OPEN I WOULD LIKE TO HERE MORE.
THANKS
LES
Old 01-13-2010, 07:20 AM
69 L88's Avatar
69 L88 69 L88 is offline
THANKS
LES
the best thing to do is cut it out still attached to the tank and put it in a secure area
Life is short Drive a fast car
Old 01-13-2010, 06:44 PM
ORIGLS6 ORIGLS6 is offline
There's a good chance the tank has pin holes on the bottom anyway. I hardly ever saw a Corvette tank that didn't have an inch or so of water in the bottom.
I had to replace the tank in my '68 and still have it (with the sticker attached) stored above my garage. The car is long gone but much of the stuff I replaced is still around. BTW, Anyone need a complete smog pump and brackets for a '68 427 Corvette?
Old 01-13-2010, 07:03 PM
Maybe be off the topic a bit, but if one choses to cut or repair a tank, after it is cleaned out, through in a few pounds of dry ice. That will displace the 02 and may keep you off the local news too.
I have seen some old welders ( like Shoney. ) use this trick on small aircraft tanks.
