Old 12-07-2009, 10:52 PM
dlv4540 dlv4540 is offline
Default 1969 L89 396 Motor
3955272 casting block dated J-14-8 with front pad of T0527KG 19B400425. The block has been cleaned and magged and is 30 over ready for the final hone to drop the pistons in. I have a set of GM 3969974 402 stock factory L78 pistons with 3/8 dimple rods that will work for the 30 over bore, standard steel 6223 crankshaft and a set of #842 service replacement heads complete. This is a 396-375HP aluminum headed chevelle block and is one of four hundred produced. Very nice condition and can ship if you cannot pick the parts up $6750. 330-770-2517
Dennis Vugrinovich
Old 12-18-2009, 05:54 AM
kenwoodj7j kenwoodj7j is offline
Default Re: 1969 L89 396 Motor
Hi what are the dates on the 842 heads and how much
Old 12-18-2009, 06:22 AM
wheelhop wheelhop is offline
It's $6750 for everything
Old 12-19-2009, 03:08 PM
The heads have service dates on the top of them which are 112467 on both heads. If you want me to seperate the heads out from the block I will for $3000.
Dennis Vugrinovich
