Old 12-01-2009, 05:02 AM
1968 nova ss 1968 nova ss is offline
Default 2005 chevy silverado /speedo
My speedometer on my 2005 chevy silverado went from a cruisin speed of 70 and then it went instantly to 120mph ans stayed stuck there for a few days .now when I start it up some days it s on 10mph others days 40mph or whatever.It is working ,just not correctly.any ideas.chris
Old 12-01-2009, 06:13 AM
bpodner bpodner is offline
Default Re: 2005 chevy silverado /speedo
There was a tsb for GM instrument clusters a while back, don't know if it's still valid. The speedo did the same thing on my 03 Z71 Suburban. After going round and round with the dealer, and reporting it to the NTSB, the tsb finally came out. The work around is to cycle the ignition key on/off, this brings the speedo down to 0 in 5 mph increments. There used to be a guy on ebay that rebuilds the clusters for a lot cheaper than GM, try a search he had a lot of good feedback. The stepper motors are what goes bad.
By the way, that vehicle was the last GM vehicle I ever bought, a $50000 POS.
Old 12-01-2009, 06:24 AM
TORONADOXS TORONADOXS is offline
Common problem. Replace the cluster and move on. It will also need to be programmed, if you are thinking of doing it at home.
Old 12-01-2009, 06:27 AM
Chateau Slate 66 Chateau Slate 66 is offline
x3... cluster
Old 12-01-2009, 06:39 AM
YenkoYS-199Stinger YenkoYS-199Stinger is offline
I have the same problem with my 05' Duramax and my tach does the same too. Sometimes I have one or the other and sometimes neither.
Chris
1966 Yenko Stinger YS-070
1967 Yenko Stinger YS-199
1969 Yenko Stinger YS-320
Southeast of Disorder
Old 12-01-2009, 06:48 AM
MosportGreen66's Avatar
My '03 Yukon did the same thing at around 85-90k miles.
Old 12-02-2009, 03:07 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
I just started to repair my 03 Silverado. Very easy to remove the cluster and take it apart. I bought a new stepper motor on ebay for $3.00. When I get it I just need to unsoldier the old one and solder in the new one onto the circuit board.
Old 12-02-2009, 03:27 AM
YENKO DEUCE REGISTRY's Avatar
Since were on the dash topic, anyone have a CD stuck in their stereo unit? My '04 2500HD won't eject the CD, lucky for me its one of my favorites! If you take the cluster out - is the head unit sitting right there for easy removal too?
Marlin
Old 12-02-2009, 03:44 AM
Ngtflyr Ngtflyr is offline
My biggest bitch with my 2000 Sierra has been the CD player. Had it replaced 3 times/4 if you count the time the dealer tried to replace it with one that looked like it had spent an hour tumbling in a dryer. Another time they didn't even check it after swapping the unit, I was PO'd when the first thing I did was put in a disk and it didn't work. They also required two service calls, one to remove the unit then 3-4 weeks later back to get the refurbed unit installed. It quit again after the warrenty expired and I've never bothered to fix it, figured it was pointless. Fortunately the disk ejected. Other than that, it's been a great truck, plan on keeping it another 10 yrs.
Dave
Old 12-02-2009, 03:57 AM
On my 2003 Hd2500 Silverado the Oil pressure guage started reading buried up or down about 2 years ago 55k.The speedo just started doing it about 2 months ago.I noticed it moving kind of clicky for about 2 days,then I drovr past a parked cop and looked down at the speedo and was doing almost 90,but the cars around me were psssing me.Now it reads 120 when sitting in the driveway.I noticed the turn the key trick right away,then I took the cluster apart and manually pushed the needle baqck,and the next day it was buried again.Truck just rolled 90K,I guess I'm screwed.
