Old 11-22-2009, 02:42 AM
njsteve's Avatar
njsteve njsteve is offline
Default Delco Remy Coil ID please: "BR 425" ?
Does anyone have a coil application chart , or know what application a Delco Remy coil with a "425 BR" would be?
It was mounted in a 1972 Pontiac V8 coil bracket I picked up a few years ago (the bracket was a unique one year only item and the coil didn't look like it had ever been touched)
Old 11-22-2009, 03:12 AM
John Brown's Avatar
Default Re: Delco Remy Coil ID please: "BR 425" ?
As I recall, that coil was only used on Pontiacs built in Canada. I'll check later to be sure.
John Brown
Old 11-22-2009, 06:21 AM
USER-3965175 USER-3965175 is offline
NJSTEVE
Delco Remy Electrical Parts Catalog lists the 1852592 coil bracket for the 1115425 coil assembly
1967-73 Pontiac Firebird Parts Catalog lists the 1852592 coil bracket in GR 2.183 for a single application only
1972 Firebird 8 CYL (exc. unitized distributor)
May fit other Pontiac applications but I don't have any other Pontiac GTO Lemans Pass. Car Parts Catalogs
USER-3965175
Old 11-22-2009, 03:37 PM
njsteve's Avatar
Wow, so that's actually the correct coil for my 72 T/A. Glad I didn't toss it out!
It has a couple dings in the cannister so I guess I'll test it, clean it up, and install it.
Thanks for the info!
Old 11-22-2009, 03:48 PM
njsteve's Avatar
By the way, do you have the specs for it? I want to check the ohm rating, etc, to see if it's still good.
Old 11-22-2009, 09:07 PM
GTO_DON GTO_DON is offline
Steve are u sure? I thought 455HO's used a unitized ignition.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
