Old 10-24-2009, 01:47 AM
firez firez is offline
Default Pilot bushing removal
Whats the best way to remove the pilot bushing out of crank. Thanks Paul
1968 LOS Rallye Green Z28
Old 10-24-2009, 01:55 AM
markjohnson's Avatar
Default Re: Pilot bushing removal
I've got a great tool for that and I just left E-Bay looking for one to show but with no luck. It's made by Lisle, it's black and cone-shaped with threads that taps and screws itself into the old bushing. Then you put a grease gun on it's zerk fitting, pump a few times, and presto......the hydraulic pressure will just pop that thing right out! I had my doubts about it when I first bought the tool, but it has worked flawlessly every time now for me.
Old 10-24-2009, 02:00 AM
X66 714's Avatar
X66 714 X66 714 is online now
Poor mans way is to thread a course thread bolt right into the center. Once the bolt bottoms out the pilot bushing walks right out. Works slick. The bushing is soft & the bolt is hard
Joe
put a bunch of wax threw the bushing and find a shaft that snugly fits into the hole. hit the shaft with a hammer and keep adding wax. The bushing will come out. Some guys use grease but that just gets messy.
Old 10-24-2009, 02:27 AM
Done, that was easier than I thought it would be. Grease and a dowel did the job. Whats be for a new bushing, roller or solid bushing. Thanks again
Old 10-24-2009, 03:34 AM
I never really like those roller bearings. I like a regular bronze bushing or maybe even one of those new Kevlar Composite bushings. Also, after you drive the new bushing in place, check the inner diameter 'cuz it like to shrink a bit and make the tranny input shaft hard to insert.
Old 10-24-2009, 05:57 AM
hanks I wen to a local speed shop and they had a brass one in stock. Thanks for all responses.
