Old 08-13-2009, 01:52 AM
harrythor harrythor is offline
Default pinion angle
Hi. Need info about pinion angle - race.I have 1969 Camaro and I use Cal Track system and split mono leafs from Cal Track.
Harry
Old 08-13-2009, 02:44 AM
1randy 1randy is offline
Default Re: pinion angle
3-4 degrees will get you started, then track tuning
Old 08-13-2009, 04:37 AM
Hi and thanks. I was measure and the trans is 0,7 degree drive shaft is 3,3 degree and pinion is 1,7 degree.
harry
Old 08-13-2009, 04:41 AM
SSRSBOB SSRSBOB is offline
4-speed trans will require more pinion angle.
Bob
Old 08-13-2009, 04:52 AM
Hi. It is a auto trans TH 400. Should I get the pinion up or down ?
Old 08-13-2009, 05:58 AM
acelr8 acelr8 is offline
Depends on if "0" is in between the 3.3 and the 1.7.If it is the pinion angle is 5,if not 1.6. 5 is fine,if 1.7 pinion down.Backup and look as I have seen several cars with positive pinion angle on the rear.The driveshaft to the pinion should be down(shaped like a V).The trans to the driveshaft should be closer to "0" for a race only app.Although this will shorten ujoint life.Jeff
Old 08-13-2009, 07:34 AM
Go to Sears and buy an angle finder. It will stick to the flat spot on the rear housing and tell you what the angle is in degrees. All of the big time chassis builders do this all the time. Phil Mondella, Kenny Kier, etc.
You want at least 2-3 degrees with an automatic. The yoke wants to point towards the ground, this helps to plant the tires upon throttle.
Bob
Old 08-21-2009, 09:14 PM
PaulK PaulK is offline
At least 2-3 degrees? Then what is the maximum? In other words, what is the acceptable range?
