Old 05-19-2009, 04:20 PM
lwkitt427 lwkitt427 is offline
Default 69 OPO
CAN ANY ONE TELL ME WHAT THEY KNOW ABOUT THE COPO ON EBAY NUMBER 290317970191 3RD TIME LISTED WOULD LIKE SOME INFO ON THE CAR PLEASE
Old 05-19-2009, 04:36 PM
PeteLeathersac's Avatar
Default Re: 69 OPO
Your eBay # is off incorrect but you're probably referring to this one...
http://cgi.ebay.com/ebaymotors/1969-DOCU...A1%7C240%3A1308
It'd be interesting to know if the mentioned alum. heads were supplied loose or installed at original vehicle delivery?.
Probably best to contact one of these fellas for info on any Scuncio cars...
Ed James
401-315-2006
[email protected]
Bob Johnson
401-568-1745
~ Pete
I like real cars best...the REAL real ones!
Old 05-19-2009, 06:10 PM
Chevy454 Chevy454 is offline
Default Re: 69 OPO
I'm curious to know if they did a complete short-block change, or even pistons, when they put the 074s on...otherwise, there ain't near enough piston to fill those chambers! Great looking car, though...
Old 05-19-2009, 06:23 PM
Default Re: 69 OPO
VIN 124379N634907
Goggling the Vin shows the Vin is listed as one documents are available for also this old thread from '02..
https://www.yenko.net/ubb/Forum1/HTML/000827.html
Exactly on the heads Rob!.
~ Pete
Old 05-19-2009, 08:57 PM
Default Re: 69 OPO
I'm pretty sure the seller is a memeber here...I would have to do some digging to come up with this username...
Old 05-19-2009, 09:08 PM
x  Baldwin  Motion's Avatar
Default Re: 69 OPO
I would say it may be the same as his Ebay user name.
Old 05-20-2009, 12:10 AM
Vern B Vern B is offline
Default Re: 69 OPO
This VIN is 641 from my 69 COPO.
Old 05-20-2009, 12:54 AM
69 Post Sedan's Avatar
Default Re: 69 OPO
When I picked bought my MN motor a year and a half ago, it had 842's on it dated 8/68. I wondered if they were dealer installed or put on at a later date.
This is what it looked like when I first brought it home.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 05-20-2009, 02:04 AM
markjohnson's Avatar
Default Re: 69 OPO
[/ QUOTE ] Rob, I gotta agree with you about not enough piston to fill those #074 chambers! I put a set of aluminum #077's on my stock 1970 LS-6 closed chamber motor and it really neutered it down. Sure it's more pump gas friendly and even runs a little cooler but it doesn't have the snap that it used to. I even used a very thin Cometic head gasket (.022, I think) to simulate the original thin steel embossed gasket. Lately, I've been thinking of a piston swap or maybe even putting back on the old #291 iron closed chambers.
Old 05-20-2009, 04:27 AM
Default Re: 69 OPO
If my memory isn't failing me [quite possible!], you're talking about a 34cc dome [L72] going into a 118cc chamber [074]...just ballparking it, that combo would be somewhere in the 9:1 range!
And that's a best case scenario, assuming the rest of the clearances/specs are spot on...
