Old 05-19-2009, 04:03 AM
2qwik2c 2qwik2c is offline
Default 1111170 distributor markings
I have a 170 distributor which appears to be a low mile take off, I would like to know what the purple paint marking means???? Also there appears to be a J on the Vacuum unit. What would this mean aswell??? Thanks
67 Biscayne 2DR L36 M40 G80 K05 F41 #'S
Attachments - The Supercar Registry 402836-DSC_1292.JPG 402834-DSC_1289.JPG 402833-DSC_1286.JPG
Old 05-19-2009, 04:06 AM
Default Re: 1111170 distributor markings
vacuum unit marking
Old 05-19-2009, 04:08 AM
One more of purple marking
Old 05-19-2009, 07:33 PM
vacuum unit marking
Are you sure that "J" is not a "4"...???
Many times the vacuum can was marked with the initial timing setting in crayon...4* is a common marking. I believe the purple paint is an inspection mark...other experts may chime in.
wilma
Old 05-19-2009, 09:07 PM
John Brown's Avatar
According to Colvin, the paint stripe is to identify the distributor without having to read the number on it.
Distributor Color Coding
Most distributors installed at a final engine assembly plant had a color code applied to the distributor housing. This was to enable engine assemblers to identify a distributor without reading the code numbers. In time, many of the paint codes wore off. Most Delco Remy blueprints call out these codes as paint spots.
John Brown
Old 05-19-2009, 09:35 PM
Great info...I checked our 1968 dated 170 and it has the purple paint mark....
wilma
Old 05-20-2009, 01:59 AM
rare4k rare4k is offline
from what i've seen and have herd most of the solid lifter cars had the purple marking on the dist
Old 05-20-2009, 04:39 AM
vacuum unit marking
wilma
Ah yes it does look like a ''4'' now that I look at it at another angle.
Old 05-20-2009, 05:17 AM
The initial timing on the vac can makes alot of sense.
Old 05-30-2009, 09:46 PM
Thanks for the help . Can anyone tell me whats the going rate for this particular distributor???? This one does not have a date code close to the build date for my car, would like to get the correct date code. Thanks.
