hello guys, anyone know the correct part no. for voltage regulator for my 70 454, car built in april. anyone know where i can get an original? thanx in advance Jim
*70 LS6 M-22, unrestored, original born with, special ordered orange. * 72 nova 557ci, LGT700 5 speed, AFR heads , Tunnel ram W/ dual 750's, 723hp/690tq, 2 1/8 Lemons |
Jim,
I'm going to assume you mean a 70 Chevelle with an LS6 going by your sign on name. 70 454 cars w/o air conditioning use an 1119515 voltage reg. LS5 cars with a/c got an 1119519. Try John Pirkle in GA. for a restored dated unit. Hope this answers your question, Chris |
thanx chris, yes it is a ls6, i have one in the garage i found today which is the same number you said 1119515, but i believe the date code is wrong for my car, it has 0G on the regulator which is july? of 70, thanx Chris
You're welcome Jim,
OG is indeed July of 70. Chris |
I have seen restored voltage regulators, where it looks like the unit was zinc plated with a old (black) cover on, so as not zinc plate the guts.
I'm thinking that the OEM metal base was stamped out of galvanized sheet. Can LS6 Ragtop educate us on this subject.....
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78 69 Camaro COPO recreation |
Chuck,
Restored units by Pirkle are indeed zinc plated. I would think that the chemical to plate would get into the unit regardless of whether or not you covered it? Never tried myself to replate one so can't really educate anybody as to what you need to do to protect the actual regulator parts. Originals bases were indeed stamped from galvanized sheet stock. Chris |
Heres one on http://www.chevelles.com/classifieds...&cat=allTC site.
Tony 55 Nomad Gasser 70 SS 427 Nova 34 Ford Sedan..Hemi powered Michigan/ Florida |
