Old 04-14-2009, 11:30 PM
69 Post Sedan's Avatar
Default Clutch & Pressure Plate Recommendations
I want to know what your suggestions are for a good Street/Strip clutch setup. The car will be run on the street most of the time but will also be taken to the track every once in a while. I used to run Borg/Warner "Brute Force" but it is not available anymore plus it made the leg shake if traffic wasn't moving.
One suggestion was Centerforce Dual Friction but I have been hearing that if that clutch gets warm it will chatter starting out in first and reverse. I am wondering if the Centerforce II will hold up and not slip.
The motor is a big block 402, approx. 500hp, in the middle of getting a M22, 11" clutch, 3:73 gears with 28" tall tires.
Any help would be great.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-14-2009, 11:34 PM
turbojet427 turbojet427 is offline
Yenko Advertising Member
Default Re: Clutch & Pressure Plate Recommendations
My buddy had a dual friction clutch in a '72 Z/28. The Z had a LS6 454, M22, 410s. I was the passenger to many 7,000rpm 2nd gear burnouts with that car. The clutch had NO issues, but the 8.5" 10 bolt finally did!!!!!
Old 04-14-2009, 11:58 PM
Fast67VelleN2O's Avatar
Centerforce dual friction is all I use.
Day 2 is Life.
Old 04-15-2009, 12:42 AM
I had the dual friction in my 91 Iroc and I did not like it. It did not hold as well I thought it would. The pedal feel was nice though although it was a hydraulic clutch.
Old 04-15-2009, 01:08 AM
How about a Hayes, Zoom etc.? I always ran the stock chevy pressure plate with the L88 disc about 50 years ago. Does those set-ups still work? I like a soft pedal.
Old 04-15-2009, 01:21 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Yes, I use the Hays street/strip set up. Clutch pedal is like stock, holds ZL-1 with M/T ET Streets.
