Old 03-28-2009, 01:20 AM
J PAUL J PAUL is offline
Default Wheel codes
I need some guidance with the following wheel codes:
EM, CL, UC. I believe these are 14 x 7. What can they be used on?
Thanks for the help.
Jeff
Old 03-28-2009, 02:58 AM
John Brown's Avatar
Default Re: Wheel codes
Jeff
CL is 70 Camaro for sure, maybe Malibu too
UC is later, like 76 and later Nova cop cars maybe others
EM don't know
I believe the offset is the same on all of them, but they have different centers from the XT and IF wheels so they would be easy to spot for anyone that is up on their wheels.
John Brown
Old 03-28-2009, 03:09 AM
Check the dates on each,as they were used varyingly.
All are 14X7 rims..
EM-used on 1973 Nova SS/Camaro SS,and 1974 Nova/Camaro.
CL-used on 1970 Camaro SS,and 71-72 Camaro SS/Nova SS.
UC-used on 1975 Nova/Camaro with the space saver spare tire.
Old 03-28-2009, 10:14 PM
Thanks for the help. I was looking for a set of XT's and someone offered me a set of the above mentioned coded for a old steel wheel look. I don't care about matching dates. So will these codes wheels fit a 69 / 70 Nova?
Jeff
Old 03-28-2009, 10:54 PM
Some have a different offset & Construction.
XT has .40 offset & Welded
CL has .34 offset & Welded
EM has .34 offset & Trued Center
UC has .34 offset & Trued Center
Does your Nova have disc brakes?
Old 03-29-2009, 03:02 AM
front disc. So if original XT's aren't needed will the variation of the others work?
Old 03-29-2009, 07:22 AM
John Brown's Avatar
They'll work. All those other cars could have come with disks, so no problem there.
John Brown
Old 03-30-2009, 05:13 AM
nova7579's Avatar
nova7579 nova7579 is offline
The IF and XT along with the JZ will all take the 68-70 hub cab. If you use the EM, CL, or UC they take a different hub cap.
Brian
Old 04-07-2009, 03:49 AM
hiperf69 hiperf69 is offline
Yenko Advertising Member
Hi,just a quick question about the 14x7 JZ wheels. Do any of you know what they were used on ? I have a set Dated late 1970 and could not find any info on them. Any help would be appreciated,Thanks, Joe.
