Old 03-11-2009, 04:37 PM
Bob Martin Bob Martin is offline
Default Brake Booster Plating
Can anybody tell me who does the best job on plating. should it be a bright gold or light gold. Thanks
Old 03-11-2009, 05:20 PM
Nasblu's Avatar
Nasblu Nasblu is offline
Default Re: Brake Booster Plating
Have had some done along with referring friends to go there. The guys name is Steve Gregori. He plates polishes out pitts whatever you need. As far as color is concerned you can plate serveral in a row and get many different finishes. Here is a pic of a booster that he just did for me.
http://www.brakeboosters.com/
Old 03-11-2009, 05:47 PM
Alss's Avatar
Alss Alss is offline
I have used Steve as well..good results
Sweet car Nasblu
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 03-11-2009, 05:22 PM
COPO CARTEL COPO CARTEL is offline
When plating a booster you can do 100 boosters one after the other and get many different finishes, the metal helps determine how light and dark the final outcome will be. There is no exact science to it.
Drive it ...Like you STOLE it !!
Steve's very good.
Old 03-12-2009, 01:21 AM
Thanks, I talked to steve today and will be sending him my parts.
Old 03-13-2009, 08:17 AM
Eddie M. Eddie M. is offline
Steve did mine and happy with it
69 ZL1 Camaro
70 Nova
Old 03-13-2009, 08:45 AM
169indy's Avatar
169indy 169indy is offline
It has been my experiance (@ a US Naval Shipyard Plating plant) that the tint-coloration (Gold-Green-Yellow-Brown) tinting is determined by the duration of DiChromate treatment after the primary electroplating coating is applied, be it zinc, cad, etc,,,
The surface condition can effect the level of 'Gloss' for lack of a better term (i.e. Brightness) Blasting parts prior to plating is usually not desired. It can be difficult to find local plate shops who even runs traditional cad tanks due to tightend eco rules (cyanide issues). It is amazing how much is plated on the cars when you really examine all the parts and you can save a ton ($$)on replacment costs if you can find a resonable priced plater to work with.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-13-2009, 05:12 PM
Your right on about all the junk that has to be replated on a real restoration.
Here is stuff from a 69 Camaro. I usually spend north of $600 bux on one car. I am lucky to be able to get Cad done here. Much better protection than Zink. IMO.
You are correct about the gold dichromate, dwell time affects the color.
I have been doing my own booster because I do not like the supper shiny finish you sometimes get with the zinc. I do blast the parts, however I then spent X amount of time smoothing surfaces to be plated. Wire brush, scotch bright buffs, and impregnated nylon wheels.
Here is one of Gregoris boosters in Zink..he does very nice work, and is fair priced too.
Old 03-13-2009, 07:07 PM
Gregori did my booster as well. Very reasonable man and very through in his work.
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
