Old 03-02-2009, 03:42 AM
chez443 chez443 is offline
Default Late 512 blocks
I have 2 4 bolt main big block with casting date of j10-9 and L 9-9. One was decked and has no # but an assembly date of 10/9/69 the other is a CE stamping. Would these be 427's or 454 block? Any help would be appreciated. Thanks
Old 03-02-2009, 04:50 AM
427.060 427.060 is offline
Default Re: Late 512 blocks
I believe they would be 454 blocks but 427 stuff would work in either one.
James
1968 Beaumont SD396
Old 03-02-2009, 05:33 AM
Unreal Unreal is offline
It is possible, although unlikely, that the J-10 block is for a COPO. I'd check the rough area adjacent to the oil filter, in hopes of finding a Camaro VIN there. I don't know the latest known COPO block date, but it's worth a look.
Old 03-03-2009, 03:41 AM
LS6 RAT LS6 RAT is offline
When viewing the cylinder case (engine block) from the bottom, if the cylinder bores have large reliefs at the bottom, that engine case (block) was designed for a 454. Those reliefs are for clearance with the quarter inch longer stroke crankshaft used in 454 applications.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 03-03-2009, 03:49 AM
HiHorse HiHorse is offline
512's. If the casting date is on the side it is a 427. If it is on the rear it is a 454.
Old 03-03-2009, 08:06 PM
Why would they cast the 512-blocks with different date-locations in late 1969, when 427 COPO-engines and 454 LS6-engines where built at the same time ?
I have a pic of the back of my friends 427 COPO-engine, and even though there is much paint on it, I´m sure the date is there. Car was built in early July.
Anders Stålklint.
Old 03-04-2009, 12:38 AM
Carleen's Avatar
Carleen Carleen is offline
Here is a 512 block, casting date 22 April -69.
Didn't they make L88,L72,L71,L89 Crate engines late -69?
http://farm4.static.flickr.com/3328/...531511a0_b.jpg
Old 03-04-2009, 02:28 AM
427's with the casting date on the rear will have the notches in the block for the 454 crank clearance.
Old 03-04-2009, 08:13 AM
I've had two 512 blocks with the casting date on the back. Both had the reliefs for the larger crank. One was a 2 bolt LE 69 Impala motor(forget the date). The other is a June 69 4 bolt CE motor.
