Old 02-11-2009, 06:12 AM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default Casting dates vs. build dates
My engine block has a cast date of A-13-69, heads cast C-28-69 and intake cast 3-27-69, but the engine pad is stamped with a build date of 04-10. What would the cast date ranges be for the exhaust manifolds, distributor, water pump, carb, and fan? I unfortunately do not know the build date of the car itself. Would some of the parts be prior to the build date of the engine and others attached on the assembly line? Is there a time line as to when parts were cast and then assembled onto the engine? Are there any publications available that explain this topic well?
Old 02-11-2009, 06:20 AM
JRSully JRSully is offline
Default Re: Casting dates vs. build dates
anything a few days to 6 months prior than the engine build date would be in range, exceptions have taken that time frame out even further
71 Porsche 911 Targa
Old 02-11-2009, 06:55 PM
Hawkeye's Avatar
Thanks for the response. What items would have been installed at the engine assembly plant vs the car assembly plant?
Old 02-11-2009, 07:37 PM
In general,an engines components were cast/made prior to the assembly of the engine as a whole.
There are a few extreme examples of some that weren't.
Flint & Tonawanda both had similar,yet different procedures..The late Fran Preve shared these procedures with Alan Colvin,and Dale has them listed on his site..
http://www.chevellestuff.com/tech/en...mbly_order.htm
And afterwards from CRG..
..The beginning of the engine dress line was a sea of racks full of engines and transmissions:small-block V-8's from Flint V-8 Engine and Tonawanda,big-block V-8's from Tonawanda,and L-6 engines from Flint Motor,plus manual transmissions from Saginaw and Muncie and automatics from Toledo,Cleveland,Warren,and Willow Run.
In the engine schedule area,the operator grabbed the next broadcast copy from the printer,verified the sequence number,noted the engine code required for that car,and moved an air-powered overhead hoist on traveling bridge rails over the correct engine rack.The specified engine was hoisted out of the rack and transferred to the next hook on the overhead engine dress line conveyor,where the throwout bearing (on manuals) was greased and installed,along with the clutch fork boot.Another operator on the other side of the line repeated the process with the specified transmission,
which was then installed and bolted to the engine.On automatics,an air tool was used to rotate the flexplate,and the converter bolts were driven,followed by the lower cover.
The VIN derivative numbers were stamped in the next operation on both the engine pad and the transmission,using a gang-stamp holder and a dead blow hammer.From here on,all the crucial detail dress ornaments were added like plug wires,coil,engine harness,battery cables,carburetor,pulleys,alternator,starter,fan and clutch,A/C compressor,power steering pump,transmission cooler lines and fill tube,A.I.R. pump,diverter valve and air manifolds,drive belts,dipstick and tube,oil filter,engine and transmission mounts,PCV plumbing,vacuum fittings,fuel pump and fuel line,radiator hoses,and (if applicable) the transmission-mounted 4-speed manual shifter and linkage was installed and adjusted (3-speed manual floor shifters were mounted on the cross-member and adjusted later on the Chassis line).
Engine oil and transmission lube were added,and the completed engine/transmission assembly was conveyed to the chassis line for installation in the subframe.The engine line inspector wrote the engine,transmission and carburetor codes on the broadcast copy and put the sheet in a box for pickup by the scheduling clerk,which was needed to create the Protecto-O-Plate at the end of the assembly line.
Old 02-11-2009, 07:43 PM
Rick, Is there any general policy on Carbs and Dist for date ranges. I have heard from a couple weeks to 4 months????
Carl
Old 02-11-2009, 07:55 PM
From what I've seen,the distributor was installed on the engine early on before it was deemed a self reliant running unit & reached the vehicle.It's date would've been anytime prior,(usually weeks before),to the engines stamped completed assembly date.
The carburetor was installed after that date,so it's date was more prior to the vehicles cowl tag started assembly date,weeks to a few months in general.
Understand these were just components sitting on a shelf,waiting for installation somewhere so some examples may differ from above.
Old 02-11-2009, 10:09 PM
Hawkeye's Avatar
Wow. That is some great information. Thanks for the clarification. Very helpful. What does CRG stand for and where can I get the publication that you took the excerpt from?
Old 02-11-2009, 10:24 PM
CRG stands for Camaro Research Group
http://www.camaros.org/index.shtml
Many publications have listed similar info..
Any one of Alan Colvins "Chevrolet By The Numbers" books for one.
