Old 01-30-2009, 07:42 AM
supercomp 8.90 supercomp 8.90 is offline
Default 69 512 ce block question
hi i am going to look at a 512 ce block with internals in the next few days, i was wondering besides the ce designation if there was anything else i could check to make sure it is an l72 by any other stampings?? he said it is a june date.
Old 01-30-2009, 07:45 AM
Default Re: 69 512 ce block question
If I remember correct look at the last three letters CRR was LS6 I rember, cant the rest.... I would like to know half I have forgot...
Old 01-31-2009, 03:20 AM
427.060 427.060 is offline
The CE (Chevrolet Engine) block won't have the engine code. There is no way to know for sure that it was/is a L-72 but if it is a 4 bolt main block there is a good chance that it is.
James
1968 Beaumont SD396
Old 01-31-2009, 06:19 AM
thanks guys for the help, i will try to get some pictures of the motor when i am there. dave
Old 01-31-2009, 06:30 AM
ssl78 ssl78 is offline
If it is a 4 bolt main motor it will have 2 large plugs not one by the oil filter
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-31-2009, 03:32 PM
HiHorse HiHorse is offline
If the short is original, should also see dimple rods and crossdrilled crank
Old 01-30-2009, 08:00 AM
you could also check the part numbers on the internals...crank and piston numbers...if it's standard bore it's probably more likely that those were the original internals than if it has already been bored over...
If it's got a cam you may be able to check out the number on that also...
Old 01-31-2009, 06:48 PM
The good 512 block will also have the holes above the oil filter flange drilled and pipe plugged for an external oil cooler. Ours is. With 40 year old engines, a lot of things may have been changed over the years. Check carefully.
