Old 01-23-2009, 11:02 PM
Default Harrison Radiator ID Help
I have a 3 row Harrison radiator that I am planning to sell. The problem is I do not know its original application. I think it may be early Nova or Impala. The Top tank is code BL and the bottom tank is code DW. It has trans cooler ports. The core measures 15 1/2 inches by 25 5/8 inches. It measures 20 3/4 from the top of the upper tank to the bottom of the lower tank and 28 inches from outside of mounting bracket to outside of mounting bracket. Any help would be greatly appreciated. I will post pictures if it will help.
Old 01-23-2009, 11:35 PM
Default Re: Harrison Radiator ID Help
Where is the filler? Left, middle or right?
Old 01-23-2009, 11:45 PM
The filler is on the passenger side.
Old 01-24-2009, 12:54 AM
63-64 Impala heavy duty cooling?
Old 01-24-2009, 01:47 AM
Sorry I can't help more...but I have defintely seen that set up in67-68 big block big cars...the filler is on the same side as yours that is pictured above...with is opposite of the way the 66 Chevelles were
I could be wrong though...
Old 01-24-2009, 01:53 AM
Thanks Bruce,
I saw the same thing. I pulled my 66 360HP radiator out of the shed and noticed the top tank was opposite also.
Thanks again,
