Old 12-28-2008, 11:44 PM
Donutblue Donutblue is offline
Default 1987 Grand National T- Tops $12500.00
Extremely clean straight 1987 Buick Grand National / (WE2) with (G80) code Posi rear end. This car has been garaged kept and covered. It has never been raced, nor has it been beat on. It’s tuned with boost set at minimum spec. No rust or rot anywhere. Body is Super straight with no dings. All body lines line up perfectly. It was stripped down to bare metal and professionally repainted about 3 years ago due aged worn paint. The paint is very flat, smooth, shines incredible, and looks like glass. It has been driven about 600 miles in the past two summers, presently about 81k. I have never driven it in the rain or winter.
Interior is close to mint with original radio concert sound and working power antenna. Runs and drives beautiful and sounds very strong with no unusual noises. No smoking no leaks! Turbo Spools nicely and goes down the road straight, with no pulling, shaking, or vibrations. Very quick with firm accurate shifts. . . ENGINE IS ALL STOCK. Due to the age of these cars I have done the recommended maintenance upgrades for this relatively stock GN. (Listed below). I do have all original parts that will go along with the car. You can drive this car safely anywhere…
Here is a list of NEW ITEMS...
BF GOODRICH TIRES ALL AROUND
BILSTEIN SHOCKS
FRONT UPPER AND REAR CONTROL ARM BUSHINGS
SWAY BAR LINKS
IDLER ARM
COMPLETE TRANSMISSION OVERHAUL WITH ART CARR SHIFT KIT
NEW D5 TOURQUE CONVERTER 2200 STALL (FACTORY)
BILLET SERVO & HARDENED INPUT SHAFT
ALTERNATOR
4 CORE RADIATOR
BATTERY
INJECTORS LUCUS #30 (CONSIDERED TO BE FACTORY REPLACEMENTS)
ACCUFAB AFPR
RJC POWER PLATE
RJC BOOST VALVE / SET @ 15PSI
WALBRO FUEL PUMP / HOT WIRED
MAGNAFLOW STAINLESS STEEL DUAL EXHAUST
T-TOP SEALS
INTERCOOLER (CLEANED AND FLUSHED)
REAR MAIN SEAL
ENGINE MOUNTS
TURBO TWEAK STREET CHIP (93 OCTANE)
COLD AC / CONVERTED R134
NEW BRAKES ALL AROUND
ADJUSTED WHEEL BEARINGS
VDO BOOST GAUGE
ALL FLUIDS FLUSHED AND REPLACED.
VACUME HOSES
SCANMASTER SCAN TOOL
ALUMINUM COLD AIR INTAKE /K&N FILTER
COIL PACK / PLUGS / WIRES / PCV VALVE /FUEL FILTER
SERPENTINE BELT
TIE ROD ENDS
O2 SENSOR
ADJUSTABLE WASTEGATE
TURBO
HEATER CORE
160 THERMOSTAT
That’s it…. You wont be disappointed with this purchase.
Very sharp GN, and hard to find in this shape.
This is the original advertisement when I purchased this car this past January, I have driven it about 600 miles since CALL George 914-438-7185 [email protected] -- Poughquag, NY 12570 -----12,500.
http://s64.photobucket.com/albums/h1...ue/Buick%20GN/
"I never think of the future. It comes soon enough." - Albert Einstein
Old 01-01-2009, 05:29 AM
70-SS/RS-L78 70-SS/RS-L78 is offline
Default Re: 1987 Grand National T- Tops $12500.00
George that is a Real Nice GN, A friend let me drive his 87 GN 3 years ago and I was hooked, I had to have one. These Turbo Regals are an absolute blast to drive. I brought a 900 mile GNX which I feel guilty about driving so it is a Garage Queen. I should have brought one with some miles on it. I am trying to work a trade for a GNX with some miles so I can enjoy the car.
Good Luck with the sale….
Kentucky Gold 70 SS/RS L78.
81 Z/28 Silver/Silver Int
09 G8/GXP #992
98 Pontiac GTP Daytona Pace Car #605
90 Olds Touring Sedan SUPRCHRGD L32
83 El Camino
Old 01-01-2009, 05:49 AM
Thanks Mark, the six cylinder turbo in these cars is amazing. I'm suprised Buick never continued with a model similar.
Old 01-01-2009, 11:31 PM
COPO427 COPO427 is offline
What I like about my '87 is the mpg. 27 on the highway. That's pretty pathetic on GM for what the new cars are getting compared to a '87. Shame on you GM. No wonder your sunk and need the taxpayers to bail you out.
And the politics sure didn't help especially when the GN was the quickest production car in '87 that would blow by the Vette. FBI ordered a bunch and swapped the tires and got rid of the limiter and used them to chase Porsches. And then the end came in '87 for the GN because it didn't look good in front of the Vette that a cheaper car could blow the doors off a Vette.
Nice car and good luck on the sale.
1970 Norwood Z28 M22, 3.73, Z21, Z87, TR 725
Old 01-02-2009, 01:09 AM
njsteve's Avatar
njsteve njsteve is offline
I remember getting pulled over for speeding by the Connecticut State Police in 1989. At the time, they had a fleet of these turbo Buicks as their pursuit cars. I guess it wasnt much of a challenge for them to catch my 3/4 ton Suburban.
