Old 12-21-2008, 01:51 AM
SS454Elky SS454Elky is offline
Send a message via ICQ to SS454Elky
Default 291 Head Value
I have a pair of BBC 291 heads. I have had them for years, they are bare and have been magnafluxed. The intake side has had a very nice gasket match port job. I dug them out to look at the date codes and learned the dates are not very close to each other. One is A 10 70 and the other is F 10 9. How much does this mismatch affect the value? Whats the going price for these things?
TIA,
Jon
Old 12-21-2008, 07:16 PM
Default Re: 291 Head Value
For someone building a hotrod motor the dates won't matter...the numbers guys will probably want them a separate pieces if they can live with the porting..I would say given the porting and mis-matched dates, maybe 300-500 each. Others may have a different idea...good luck.
Old 12-22-2008, 12:05 AM
427.060 427.060 is offline
I would guess about $600 to $800 for the pair. The porting hurts more that the dates. A nice ready to install set usually sells for around $1200 to $1500.
James
1968 Beaumont SD396
Old 12-22-2008, 05:29 AM
JRSully JRSully is offline
The post Jan 70 291's up until about May 70 or so seem to bring more $$ than the 69 cast 291's because they are rarer. You need to check the plug holes on both of those heads as the 69 head probably has the large plug and sometime after Jan, Feb or so they went to the peanut/tapered seat plug
71 Porsche 911 Targa
Old 12-22-2008, 06:02 AM
Sully, all of my late 69 L78 cars have the tapered seat small plugs...I think the transition was earlier than you mentioned...my earliest casting dates are late Oct/early Nov and they ahve the peanut plugs.
wilma
Old 12-23-2008, 07:30 PM
Thanks for the info!
