Old 11-20-2008, 06:49 AM
ctbZ ctbZ is offline
Default STD bore '70 CTB
STD bore '70 CTB
Link to Pictures
1970 standard bore LT1 4-speed Z28 short block. Dated Feb. 10 '70.
Cast number B 10 0
Suffix code V0126CTB
Original forged crank shaft 1182
Pink "0" connecting rods
Pistons #3959456
Harmonic balancer #3942538 8-inch
Winters intake #3972110 original finish, never media blasted, w/ heat shield
780 CFM carburetor #3972121 LIST-4555 O22
Thermostat housing
Coil bracket
Choke spring mechanism
Valve covers
Ignition shield
Green tip Oil Dip Stick
Oil cap
Engine Lift Brackets
7772 Fan (B70)
Asking $5,000.00
Please PM any questions.
Old 11-20-2008, 11:41 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Default Re: STD bore '70 CTB
Hmmm. How could it be cast on Feb 10 and the stamping says it was built 15 days before it was cast on Jan 26th?? Something doesnt add up here.
EDIT:Okay just looked at the pics, the stamping is V0216CTB which makes more sense.
Old 11-21-2008, 11:32 AM
Thank you for pointing out the typo. Sorry for the confusion. It is indeed a V0216CTB.
