Old 09-28-2008, 06:33 AM
Zach Carter Zach Carter is offline
Default B-Body Ladder Bars
What are people doing for ladder bars for B-Bodys these days. We've got a 68 427 Biscayne 500hp, M22, 12 bolt with 4.56 and tons of wheel hop.
Thanks
Zach Carter
1969 Biscayne L72 M22 Real
1972 Nova SS-Former Drag Car
Old 09-28-2008, 07:35 AM
mockingbird812's Avatar
Default Re: B-Body Ladder Bars
You might start with replacing your rear suspension bushings with something stiffer than rubber like poly urethane and see what you got.
Sam...
Old 09-28-2008, 08:43 AM
I don't think I ever saw ladder bars on a big car. I believe they still make a sway bar kit and also a set/pair of solid torsion bars. Maybe Lakewood or Competition Engineering. But I would do what Sam suggessted by changing all your bushings, snubbers and what have you with the new style material they have out now. Can't think of the name of the material they use for the new suspension kits. Neopreme maybe my spelling!
Old 09-28-2008, 05:56 PM
Dog427435's Avatar
I had a '66 L-72 4 spd car back in the late sixties - When running slicks, besides wheel hop, I was having a
terrible time tearing out trailing arms and the transmission crossmember mounts.
I made a set of ladder bars and ran them backwards to the frame ends. This set up though unorthodox
combined with air bags in the rear springs solved my problem for quite some time.
The car set up high in the air Gasser style held together for a couple years of hard street/strip launches!
Old 09-28-2008, 08:06 PM
Hey Dog - got a close up of your rear quarter window? Looks like you collected a few stickers at the local tracks !!!!
Sam...
Old 09-30-2008, 01:37 AM
I've got Energy Suspension bushings already in the upper and lower control arms along with the panhard rod. Lakewood makes a ladder bar for coil spring cars that are 25"'s long. Part# 20463
Zach Carter
Old 09-28-2008, 06:21 PM
1967 Impala's Avatar
1967 Impala 1967 Impala is offline
Biscayne
If you look at this video it talks about how they changed the instant center by raising the upper control arm brackets
Plus it is a relly cool car.
1967 Impala 454ci
