-   Parts/Memorabilia - Wanted (https://www.yenko.net/forum/forumdisplay.php?f=84)
-   -   69 BB upper alt bracket (https://www.yenko.net/forum/showthread.php?t=97873)
Alss 03-21-2008 06:10 AM
Need a decent original one..the repops fit like cr@p!! Thanks
ALbert
SS427 03-21-2008 06:17 AM
Re: 69 BB upper alt bracket
Don't get me started on reproduction sh!t! Half of what I have ordered has had to be returned. I am down to the wire on these two cars and I have to deal with this crap!
I might have one and will look for you.
427king 03-21-2008 06:25 AM
Albert, you are supposed to stick a crowbar in the slot that the upper alt bolt goes thru and then bend the main body. You wont have any adjustment ability in the belt so make sure you get one that is about 1/4 on an inch longer than when the alt is positioned closest to the water pump. If you try and go beyond that the bolt will strip. They are the worst reproduction part ever made. But if you work on them for 4/5 hours youll get it working decent. https://www.yenko.net/ubbthreads/imag...s/confused.gif I try and buy every original i can get my hand on.
SS427 03-21-2008 07:16 AM
Sorry Al. I was SURE I had a 69 bracket but cannot find it anywhere. https://www.yenko.net/ubbthreads/imag...lins/dunno.gif
WILMASBOYL78 03-21-2008 05:51 PM
Just took a look in my stash..no luck, only 70 parts...made a few calls....Sully has one...you will here from shortly. If it turns out not to be correct...you can borrow one off our restored cars for the show....I will also check our other storage bin...good luck.
wilma
Alss 03-22-2008 05:18 AM
wilma
Thanks WIlma..not for the COPO..have a good one on already..this ones for the ZL-1 Malibu. Thanks everyine for looking in your parts stashes.
ALbert
JRSully 03-22-2008 06:11 PM
Al, I believe I may have what you need, just have to check to see what is on my 70 car and I'll get back to you shortly. Thx SULLY
JRSully 03-23-2008 04:46 PM
Al, I have a 69 BB bracket for you, send me your address I'll throw it in the mail to you. SULLY
Alss 03-24-2008 11:48 PM
Sully..thenks alot!! https://www.yenko.net/ubbthreads/imag...iggthumpup.gif
PM sent
