69 x33 camaro
Re: 69 x33 camaro
It was on ebay last week. 711 72 72, real tag.
Dont recall the ad listing the VIN to see if it lined out. dave |
Re: 69 x33 camaro
Yep. I almost bought that one. One issue, the vin was cut out with the dash when it was made into a racecar, and subsequently it was lost. So, no vin. https://www.yenko.net/ubbthreads/imag...lins/frown.gif
Re: 69 x33 camaro
This is the one I just got 3 weeks back.I foung the hidden partial vins but I suppose the value is gone since the original dash was removed.
Re: 69 x33 camaro
I wonder if there is somewhere to get a VIN plate made. Here's a REAL car, just missing the vin plate. That's why I did not touch it was well.
Re: 69 x33 camaro
it only costed me this
http://s81.photobucket.com/albums/j2...urrent=S10.jpg All I was looking for was an x11 coupe like I had for 16 years.I may just get the restoration started and sell it to get a standard camaro.Or is this car's value gone because the original vin is gone? |
Re: 69 x33 camaro
Once a Z-28, always a Z-28. You could go to the local state police (in most states, check yours) and have them reissue a new VIn, however, it will not be a chevrolet 124379 vin.
If someone out there still certifies Z's then with that paperwork you might be ok? Of course, it is still a vintage Z-28 made in to a 1/4mle Racecar, and you can always restore it to those specs. Rich |
Re: 69 x33 camaro
if you take the heaterbox off the vin should be there on the firewall and if you take off the cowl below the windsheild the vin should be stamped on the passenger side on top
Re: 69 x33 camaro
if you take the heaterbox off the vin should be there on the firewall and if you take off the cowl below the windsheild the vin should be stamped on the passenger side on top [/ QUOTE ] Right, but he still needs a VIN tag on the cowl, even though with that information he can recreate the whole vin. |
Re: 69 x33 camaro
124379N641855
