1969 Camaro BB Frame Mounts
Looking for a set of original GM 396/427 frame mounts for my RS/SS. PM or email me: [email protected]
Thanks! Tony |
Re: 1969 Camaro BB Frame Mounts
No one?
I saw an NOS set sell on Ebay recently for $600.00.
Believe me,if I had them,you would know it already..... |
Are you kidding??? Maybe we're talking about two different things here--these are the steel brackets that mount to the subframe in order for the BB engine to sit a little offset to the passenger side of the engine compartment. I can get a NOS set from Heartbeat City for $199...just would rather get a used set for less $.
Not to justify the price,but these were for 4 NOS items, 35 years old.Frame & Block mounts.You would think the rubber would not be pliable after all those years.Maybe they were and thats why they sold for that? https://www.yenko.net/ubbthreads/imag...lins/dunno.gif
With the crazy prices of anything '69 Camaro, I can see $600 for the entire set...wish I'd bought up all this stuff at the swap meets years ago! https://www.yenko.net/ubbthreads/imag...lins/frown.gif
I parted out a 69 L78 Nova. Not much left of it as it was an old drag car. I do have the frame mounts buried in my garage. They should be the same as 69 camaro. If you know the stamped numbers on them let me know and I'll check them. $200 for the pair.
I had NOS non-interlock motor mounts on my 427 2 bolt, and they were still pliable. When I replaced the motor with the CE COPO motor I was planning to use the interlock style. However, they were about 3/8" shorter than the originals, and I was afraid the crank pulley would hit the cross member. I bought them as correct, but maybe they were for another application. I ended up reusing the NOS ones. Found a b/b with A/C and A.I.R. lift stop on a 69 Impala b/b. Does anyone know if it will work on a Camaro?
| All times are GMT. The time now is 05:25 AM. |
