-   Technical & Restoration (https://www.yenko.net/forum/forumdisplay.php?f=86)
-   -   1970 vs 1971 LS-6 (https://www.yenko.net/forum/showthread.php?t=70850)
Stefano 03-04-2002 09:34 PM
Re: 1970 vs 1971 LS-6
Used only in the Corvette production for 1971, If memory serves only 188 were produced. I have never had an original appart, and GM specs have varried, but I believe it to be a carry over from the 1970 Chevelle only platform, just with the open chamber aluminum heads.
Same cam and pistons ect...??
Dutchesscamaro 03-05-2002 06:58 AM
1970 vs 1971 LS-6
Can anyone describe the difference between the 1970 and 1971 LS-6? 450hp vs 425hp
Compression 11.25 vs 9.x?
How was this obtained closed chamber piston with open chamber heads?
Was the cam changed?
Help here would be appreciated...
Tilbillies 03-11-2002 06:06 AM
1970 LS.1 rated @ 450 H.P. had 11.25:1 compression ratio. Mechanical lifter cam, and an 800 CFM Holley, rectangular port cast iron heads, forged pistons and four bolt caps.
1971 LS:6 rated @ 425 H.P. dropped the compression ratio to 9:1.
