1971 Camaro, Strip/Street
FOR SALE: 1971 CAMARO STRIP/STREET CAR
GOURGOUS BRIGHT RED PAINT, CAR HAS BEEN COMPLETELY GONE THORUGH OVER THE LAST 4 YEARS. Weld Draglight wheels with MT 28x10.5 slicks on back and skinnys up front. 10-bolt 8.5 rear end, 4:10 Richmond gears,TH-350 tranny,3000rpm converter, SSM lift bars, CE adjustable drag shocks on front and back, Moroso springs up front, new heavy duty leafs on back. Front disc brakes with all new front end and poly bushings, solid body mounts, solid motor mounts, CE subframe connectors, custom built drive shaft, drive shaft loop, full Auto Meter gauges, B&M Pro-stick, racing seats with 5-point harnesses, full interior except rear seat and door panels, trunk mounted battery w/shut off switch, 6-point roll bar. To many other things to list. Motor: 355sbc, fully balanced rotating assembly, 4-bolt block with ARP studs, steel crank, GM rods, TRW 11:1 pistons, Vic. Jr. Intake, Holley 800cfm DP carb, MSD ignition,1 5/8 headers, HP GM steel heads with 2.02 / 1.60 Manley S.S. valves, Lunati springs, rockers studs, roller rockers, Lunati hyd. Cam, NOS Super Powershot nitrous system with a 1-gallon fuel cell and electric pump, 3 Flowmaster exhaust. Motor is tame enough to be driven on the street and has gone 7.09 in the 1/8th at 97 mph Car with tandem axle car trailer with brakes and ramps $10,200 OBO. Without trailer $9,500 OBO. Located in Springfield MO. FOR INFORMATION CALL: 417-848-4464 Pictures can be seen at <A HREF="http://www.geocities.com/imq707s2000/IQRaceworks.html " TARGET=_blank>www.geocities.com/imq707s2000/IQRaceworks.html </A> |
