-   -   2001 Pontiac Sunfire Maintenance (https://www.yenko.net/forum/showthread.php?t=109522)
72-SS-L48 03-24-2010 08:04 AM
Hi Guys,
I have a 2001 Pontiac Sunfire. It’s a great little 4 cylinder that is super reliable. Currently the car has 73K miles. I'm getting concerned that the soon to be high mileage will catch up with the car and I will start to have mechanical problems. With that said what type of preventative maintenance do you guys recommend? Water pump, timing belt / chain, trans fluid change, etc.?? I also notice that the suspension is starting to squeak. What are some bushings that should be replaced around this mileage?
Thanks!
-Dave
hep1966 03-24-2010 05:06 PM
Re: 2001 Pontiac Sunfire Maintenance
I drove my 2000 Cavalier up to about 197,000 miles with the original engine and transmission never taken apart. It didn’t use any oil between changes and I still got over 30 mpg. I bought it with about 120,000 miles. The original owner was a friend who did regular oil changes. All the maintenance I ever did with the car was oil changes and lots of brakes and rotors. It was my driving school car. It needed a new AC compressor and radiator at about 150,000 miles. I’d still be driving it but the state makes us replace cars after 8 years or 80,000 miles, whichever occurs later. My current work car is a 2004 Cavalier with about 145,000 miles. The ecotec motor is much more powerful. The front end of the 2004 was squeaking a lot and we tracked it to a front right swaybar bushing. Not the end of the bar but the bushing closer to the middle. I thought it was a strut because it was very noisy. Yours may have the same problem. Try spraying lubricant on the bushings as they are difficult to replace. Not a lot of room to work in there. Check out this link to correct an oiling problem if you have the ecotec motor.
http://www.chevytalk.org/fusionbb/sh...hp?tid/219345/
72-SS-L48 03-24-2010 06:01 PM
John,
Thank you very much. Your post was very reassuring. I know these are reliable cars and your high mileage cavilers are great for me to hear.
Dave
