-   -   Complete TH400 Swap 66-67 Chevelle $500 Virginia (https://www.yenko.net/forum/showthread.php?t=108598)
bulletpruf 02-02-2010 08:16 PM
Everything you need to swap a TH400 into your 66 or 67 Chevelle.
Transmission is a fresh Fairbanks rebuild (maybe 50 miles?) with reverse manual valve body. It worked flawlessly for me; no slipping, firm shifts, no issues. Just pulled it from my car 3 weeks ago to swap back to a 4 speed. Drained the pan when I pulled it; no debris whatsoever. Looks great inside.
Converter is a fresh 10" 3,500 stall Fairbanks.
Shifter is a B&M; one of the smaller units with a brushed aluminum cover (kind of like a Hurst Quarter Stick).
Flexplate included if you need it - from a 396.
Comes with the correct 58.5" driveshaft.
Comes with a transmission cooler as well.
Would cost you more than $2000 to buy all this new. Will sell it all for $500. Guaranteed to be in good working order.
E mail if interested.
Will accept some 66 Chevelle parts in trade - nice inner fenders, 444 or 621 bellhousing, 4 speed pedals, linkage, flywheel, 66 BB oil pan, correct alternator (1100693), distributor, starter (1107365) , or carb for 66 396, rect. port BBC heads, gas tank (good used is ok), original 66 Harrison radiator, original 66 Chevelle big block fan (3839282), 4 sp console, exhaust manifolds (3883999 and 3868874), shifter, 986529 AM/FM pushbutton radio, outside rearview mirrors.
I'm in Woodbridge, VA - about 25 miles south of D.C. on I-95. Have a road trip to Ohio planned in a few weeks and can deliver on the way.
Scott
