-   -   1969 L78 motor (https://www.yenko.net/forum/showthread.php?t=107993)
dlv4540 12-27-2009 03:51 PM
1969 L78 motor
I'm relisting this engine due to the fact I have lost contact with the buyer. 1969 396 4 bolt standard bore block casting number 3955272 dated K-4-8 and has been cleaned and magged and is standard bore. Front pad is stamped T1113JH 19W356950. I have the original 11 to 1 pistons with a set of 3/8 dimple rods, 6223 steel standard crankshaft, 8 inch timing cover and original 8 inch balancer, 3919840 square port heads redone dated I-18-8 and J-22-8, pushrods, headbolts and a new double roller timing chain for $4500. 330-770-2517
